The following is a section "Correlation Amplitude and the Energy-Time Uncertainty Relation" from Sakurai's Modern Quantum Mechanics book page 79:
Question:
  • Why does it state that the oscillations are rapid unless $|E-E_0|$ is small compared to $\frac{\hbar}{t}$? Also, what is the particular importance of the interval $|E-E_0| \approx \frac{\hbar}{t}$ being narrow compared to $\Delta E$ (defined as the width of $|g(E)|^2\rho(E)$) which I think allows us to assume that $|g(E)|^2 \rho(E)$ is approximately constant (which then implies that $C(t)$ is zero by allowing us to take $|g(E)|^2 \rho(E)$ out of the integral (2.1.72) and hence an integral on an oscillating function of that kind is zero)?
For the first question, I like to think of things this way: if you evolve long enough you will begin to notice that the integrand oscillates and is not monotonic this means you will begin picking up positive and negative areas under your integral causing cancellations. In order to avoid this, either do not evolve long enough or have exceedingly low energies so that your period is very large.
Now you could ask at what scale will one being to notice this cancellations? It will be roughly $|E-E_0| \approx \hbar/t $. Now we know that our integrand is peaked at $E_0$ with width $\Delta E$, but if this scale is much larger the our $|E-E_o|$ scale i.e contains the domain of massive oscillations then when integrate we will be getting the scale where we have massive cancellations and therefore getting something close to zero.
Amara
  • 1,592
