12
As I have understood it, the Standard Model includes particles that carry the different forces, e.g. the electromagnetic (EM) force, the gravitational (G) force. When talking about EM fields such as visible light or microwaves, the associated particle is said to be the photon. But what about a static EM field without any electricity, like a common household magnet? How does that magnet communicate its force? Via photons?
Cosmas Zachos
  • 67,623
Amplifying the fine answer of Kostya, to address Dirty Harry's question. Static forces, such as slow moving magnets, like the one you mention involve extraordinarily low energy photons, so, since these are massless, extraordinarily long wavelength photons: their technical name in relativistic Quantum Field Theory, where the carrier notion is most useful, is "infrared" photons.
In macroscopic, classical settings, they don't add much intuition to the picture, and, as the questions suggest, they confuse the landscape more than illuminate it. Nevertheless, they connect seamlessly with our low energy, small $\hbar$, normally non relativistic world.
Indeed, technically, the infrared limit of the tree-level ("Born") amplitude of particle interactions yields the Coulomb potential, as detailed in, e.g. Peskin and Schroeder's book (M. Peskin and D. Schroeder, An Introduction to Quantum Field Theory, (4.127-4.136))or this answer; (for a n.r. treatment, see this answer here ), and the associated Maxwell's equations, and so all the phenomena the question would contemplate. These amplitudes conserve energy and momentum, except for ultra-short times not of relevance here, so, no, the magnet is not constantly losing or gaining energy by emitting and absorbing these zero energy limit photons, unless the test object moves... infinite wavelength photons... they are a limit. A roiling sea of nothings.
Nevertheless, this sea of nothings informs the very active and responsive vacuum of QFT. If, however, there is movement of the test body subject to the magnet, yes, the force at a distance is carried by gadzillions of such photons that take energy and momentum from the magnet and transfer it to the object, anisotropically, and collectively shaping what we perceive as the classical force.
Mind you, even in non-relativistic quantum mechanics, most of the time one need not consider them, in calculating energy spectra, and one works with a semiclassical Coulomb field of, e.g., an atomic nucleus, the 1/r potential of the Schroedinger eqn. Only in subtle cases of relativistic corrections, like the celebrated Lamb shift (1947, that started utilization of QFT) would one see subtle correctional effects to energy levels due to this picture.
Nevertheless, smoothing out the correspondence limit of QFT has been, historically, sufficiently intriguing to have Feynman suggest to a student to calculate planetary motions through (hypothetical) massless graviton exchanges (it actually works!), in Newton's gravity, not EM. (see WP article. )
As indicated above, however, intuition is tricky with delocalized (λ⟶∞) entities such as these: so, when you think you can describe repulsion of two particles with a metaphor of two boats where a boat throws a basketball at the other, you run into deep perplexity when you consider that the two boats could also attract each other, by the very same exchange of a basketball!! I suspect the wisest attitude is to leave particle mediation to QFT, where it was born, and where it does most good.
Cosmas Zachos
  • 67,623
Yes -- the carrier for any electromagnetic interaction is a photon. Including ordinary magnets.
You might ask: "Why then can't I see those photons?" Well, even from classical point view, the photons can have different wavelenghts. And with the magnet you deal with really large wavelenghts, while one cannot "see" radiowaves. While also I think that one cannot even use the concept of "interaction carrier" without working in a context of quantum field theory anyway.
ACuriousMind
  • 132,081
Kostya
  • 20,288
-2
The force carrier of electrostatic and magnetic fields cannot be the photon. The photon carries energy away from the system in a combined electromagnetic field. However no energy is carried away from either of two magnets repelling each other, for example. Left for decades, two opposing permanent magnets will still be exerting the same force upon each other. The energy for this force appears to be free, unless the mass of the magnets is slowly changing. I have been running exactly such an experiment for nearly fifty years. I have several magnets floating one above the other held by a balance between gravity and their mutual repulsion. They are still at the same distances from each other after fifty years. The total force exerted by the magnet pile against gravity is quite large by now. Where did all that energy come from? Low energy photon emission? I don’t think so. Photons are EM phenomena. The force carriers of the electric field and the magnetic field are yet to be understood. There is a clear difference between the near-field E and M r^3 behavior and that of the combined EM r^2 far field.
