Supposedly, "Any divergence-free vector field can be expressed as the curl of some other divergence-free vector field" over a simply-connected domain.
So, what is one such vector potential which works for half of the Coulomb field?
To be clear, I want a vector potential whose curl equals the vector field $\mathbf R/|\mathbf R|^3$ for $z>0$ (for any $x$ and any $y$). $\mathbf R$ is the position vector $(x,y,z)$.
I know the scalar potential method is usually used instead of this, but am curious about how ugly a vector potential would look. If this gets answered, it should then be easy to answer this.
bobuhito
  • 1,046
  • 16
In cylindrical coordinates, this potential (pointed angularly about the z-axis) works: $$\vec{C} = \frac{1-\frac{z}{\sqrt{r^2+z^2}}}{r} \hat{\phi} $$
By choice, the curl also contains an impulse along the singular line (x=0, y=0, z<0) to zero the divergence. So, a solenoid sleeve from infinity can thereby generate the Coulomb field. In hindsight, I guess this is obvious, but it's interesting to do away with electric monopoles and consider an electron to be tied to infinity (or maybe a nearby positron) this way.
bobuhito
  • 1,046
  • 16
