45
This press release by NIST, titled "NIST Physicists ‘Squeeze’ Light to Cool Microscopic Drum Below Quantum Limit", makes the following claim:
The new technique theoretically could be used to cool objects to absolute zero, the temperature at which matter is devoid of nearly all energy and motion, NIST scientists said.
I'm not sure that's exactly what the NIST scientists said, nor what they meant. I'm very suspicious of anyone who claims to be even theoretically capable of reducing a mechanical system to absolute zero.
The full publication itself is at
Sideband cooling beyond the quantum backaction limit with squeezed light. J.B. Clark et al. Nature 541, 191 (2017), arXiv:1606.08795.
Can someone with access to the actual article in Nature clarify whether the news article at NIST was accurately reporting on the content of the Nature article regarding achieving absolute zero? The abstract instead references cooling "arbitrarily close to the motional ground state".
I'm not looking for a debate about whether or not reaching absolute zero is possible, nor a discussion about the discrepancies in definitions of absolute zero. I just want someone to clear up the probable discrepancy between what NIST wrote and what Nature published.
Emilio Pisanty
  • 137,480
Sasha
  • 516
Let's go through the article's abstract (emphasis added by me):
Quantum fluctuations of the electromagnetic vacuum produce measurable physical effects such as Casimir forces and the Lamb shift. They also impose an observable limit—known as the quantum backaction limi on the lowest temperatures that can be reached using conventional laser cooling techniques. As laser cooling experiments continue to bring massive mechanical systems to unprecedentedly low temperatures, this seemingly fundamental limit is increasingly important in the laboratory.
Right, conventional laser cooling cannot get a system below a certain minimum temperature. This is essentially because lasers (or microwave sources, or whatever coherent field generator you care about) output a so-called coherent state, which has a finite width in both of its quadratures. This limit is called, later in the abstract, the "quantum backaction limit", as we'll see in just a moment.
Fortunately, vacuum fluctuations are not immutable and can be ‘squeezed’, reducing amplitude fluctuations at the expense of phase fluctuations.
Right, coherent states aren't the only possible states of the electromagnetic field (or any other harmonic oscillator)! It is possible to generate so-called "squeezed states" where one of the quadratures is more narrow than the other. These squeezed states do not violate the Heisenberg uncertainty relation: you get squeezing in one direction at the expense of broadening in the other. This is directly related to what the authors refer to as reducing amplitude fluctuations at the expense of phase fluctuations. I'm not getting in the details on this because it's out of bounds for what OP is asking.
Here we propose and experimentally demonstrate that squeezed light can be used to cool the motion of a macroscopic mechanical object below the quantum backaction limit.
Ok fine. They get beyond the "quantum backaction limit" because they're not using a normal coherent state. They use a squeezed state.
We first cool a microwave cavity optomechanical system using a coherent state of light to within 15 per cent of this limit. We then cool the system to more than two decibels below the quantum backaction limit using a squeezed microwave field generated by a Josephson parametric amplifier.
Yep, as we just said, using a squeezed state lets you get past the limit you have with normal coherent states.
From heterodyne spectroscopy of the mechanical sidebands, we measure a minimum thermal occupancy of 0.19 ± 0.01 phonons. With our technique, even low-frequency mechanical oscillators can in principle be cooled arbitrarily close to the motional ground state, enabling the exploration of quantum physics in larger, more massive systems.
Ok so there we clearly see that they did not get to absolute zero. They still had about 20% of a phonon (one quantum unit of vibrational excitation) in their oscillator, whereas absolute zero would be zero phonons. They say that in-principle you can used squeezed states to get to arbitrarily low temperatures (i.e. arbitrarily low phonons). That may technically be true, but to get arbitrarly low temperature you need arbitrarily much squeezing, which is very, very hard to actually do in the lab. They're making an "in-principle" statement where the conditions for the in-principle thing to be achieved are totally unrealistic, and what's more, it's not even known whether the theory accurately describes the physical system in the parameter range you would need to get, say, $10^{-10^6}$ phonons (see comments under Emilio's answer for more on this).
Statements like that are still useful, because they tell the reader that there's no known hard limit to how far you can go with the squeezed state technique, i.e. the limits are entirely practical. This is important because other protocols could have in-principle limitations. For example, I might have some protocol which cools an oscillator but cannot possibly get below 0.3 phonons because of something baked into the physics. In that case, you know that if you need a phonon number lower than 0.3, don't even consider using my protocol.
DanielSank
  • 25,766
Daniel Sank has done a very good job at explaining the detailed physics as explained in the original paper, but he's not talked much about the NIST press release and I think it's worth mentioning some things about it.
More specifically, the press release makes two claims which misrepresent the physics of the paper, as explained by Daniel, and indeed those claims are inconsistent with the laws of thermodynamics.
  • The new technique theoretically could be used to cool objects to absolute zero, the temperature at which matter is devoid of nearly all energy and motion, NIST scientists said.
    This is incorrect. The new technique gives us a method that could, as far as we know with the hard information we know now, be used to cool objects to arbitrarily cold temperatures $T$, but it does not allow us to actually reach absolute zero.
    The valuable part of the new method is that all previous methods to cool stuff down have some sort of fundamental limit: for instance, even quite sophisticated 'sub-Doppler' laser cooling methods will be unable to cool down atoms to temperatures where the atom's momentum is smaller than one photon momentum, because that's the currency of the laser beam.
    In the new method, if you have enough resources (i.e. if you can build a device that can produce light that's 'squeezed' to an sufficiently large extent) then you'd be in principle be able to cool down to any positive temperature $T>0$ you cared to name, down to a zeptokelvin if you so desired, as far as we know. That said, the technique almost certainly has some form of fundamental lower bound on what temperatures it can reach, but we just don't know what that limit might be as of yet.
    Where the press release strays is in confusing 'arbitrarily close to zero' with 'actually equal to zero', and indeed the third law of thermodynamics implies that we can never actually reach absolute zero. Even if the new technique did turn out to have no hard lower limit, and it could indeed get to arbitrarily low temperatures (itself unlikely), as far as the third law goes, that would still be a positive temperature and, however small, it is still infinite steps away from actual absolute zero.
Moreover, while we're here, the press release makes a second similar incorrect statement:
  • NIST scientists previously cooled the quantum drum to its lowest-energy “ground state,” or one third of one quantum
    Again, this is not true, and for the same reasons (though maybe this one can simply be chalked up to just being internally inconsistent). In the previous experiment being described, the system was cooled down so that it was in the ground state 70% of the time, and it had an excitation energy of just a single quantum the other 30%. This means that it's pretty cold, but it does not mean that it is actually in the ground state - it's still at a finite temperature.
Emilio Pisanty
  • 137,480
