I have read this post: 'How do you define the resonance frequency of a forced damped oscillator?'
And I see that the resonant frequency occurs at the undamped oscillation frequency $\omega_0$ as opposed to the damped oscillation frequency $\omega_d$. I don't understand why this is the case though? In the post, it stated that at resonance the ' energy flow from the driving source is unidirectional', and I'm sure this is the reason why it is the natural frequency of the system not the driving frequency at resonance, but I didn't really understand the rest of the post to see if it answered this question.
Meep
  • 4,167
Confusion arises because there are a number of ways in which to define resonance.
In mechanical systems, e.g. a spring-mss system, it is much easier to measure amplitudes rather than velocities and so graph to illustrate forced oscillations and resonance are of amplitude of driveN system against frequency of constant amplitude driveR.
When the amplitude of the driveN is a maximum there is amplitude resonance.
The frequency at which amplitude resonance occurs decreases as the damping of the driveN system increases.
For small amount of damping that change in amplitude resonance frequency is small and the amplitude resonance frequency is approximately equal to the free oscillation frequency of the undamped driveN system.
In electrical systems, e.g. an LCR series circuit, current is easier to measure than charge and so it is current which is usually measured to investigated forced oscillation and current resonance.
In that case the maximum current in the driveN system occurs at the same frequency irrespective of the amount of damping of the driveN system.
The current resonant frequency is equal to the free oscillation frequency of the undamped driveN system.
This is also energy resonance where the maximum power is transferred from the driveR to the driveN system.
Velocity resonance for a mechanical system is equivalent to current and energy resonance for an electrical system and charge resonance for an electrical system is equivalent to amplitude resonance for a mechanical system.
Now amplitude $A$ and maximum velocity $v$ are connected $v=\omega A$ where $\omega$ is the frequency of the oscillations.
So the amplitude resonance graph is of amplitude of the driveN $A_{\rm N}$ against frequency of the driveR $\omega_{\rm R}$ whereas velocity resonance graph is of maximum velocity of the driveN $\omega_{\rm R}A_{\rm N}$ against frequency of the driveR $\omega_{\rm R}$.
It perhaps should be of little surprise that the two types of resonance occur at different driveR frequencies.
Farcher
  • 104,498
