The stress tensor in continuum mechanics (i.e. the negative of the space-space part of the stress energy tensor in relativity1) takes the form: $$\newcommand{\p}[2]{\frac{\partial #1}{\partial #2}} \newcommand{\f}[2]{\frac{ #1}{ #2}} \newcommand{\l}[0]{\left(} \newcommand{\r}[0]{\right)} \newcommand{\mean}[1]{\langle #1 \rangle}\newcommand{\e}[0]{\varepsilon} \sigma_{ij}=-p\delta_{ij}+\eta \l\p{v_i}{x_j}+\p{v_j}{x_i}\r . \tag{1}$$ As the name suggests this is a tensor but I am not clear what type of a tensor and can't seem to find a resource which tells me and it is my assumption that (1) is not written in tensor notation (i.e. correct index position). Thus my question is this: how do we write the stress tensor (1) in actual tensor notation?
1Stress-energy tensor: Its relation to force?
  1. It seems that OP essentially wants to consider an incompressible Newtonian fluid on a Riemannian 3-manifold $(M,g)$ (as opposed to, say, a perfect relativistic fluid).
  2. Next, we should write local coordinates $x^i$ with an upper (as opposed to a lower) index, as user AccidentalFourierTransform suggests in a comment above.
  3. The Kronecker delta should be replaced with the metric tensor, cf. e.g. this Phys.SE post.
  4. Partial derivatives $\partial_i$ should be replaced with (Levi-Civita) covariant derivatives $\nabla_{\!i}$. This point 4 and the previous point 3 were also suggested in the answer by user Chester Miller.
  5. Use the musical isomorphism to raise and lower indices $v_i=g_{ij}v^j$ on the incompressible velocity field, ${\rm div} (v)= \nabla_{\!i}v^i=0$ .
  6. Then both sides of OP's eq. (1) becomes a symmetric (0,2) covariant tensor $$ \sigma_{ij}~=~-pg_{ij}+\eta \left(\nabla_{\!i} v_j+ \nabla_{\!j} v_i\right), \qquad p~=~ -\frac{1}{3} g^{ij}\sigma_{ij}. \tag{1'} $$
The equation you gave is expressed in terms of Cartesian coordinates, where the distinction between covariant and contravariant components does not exist. If you want to express this Newtonian fluid constitutive equation in terms of "actual" tensor notation, the partial derivatives on the right hand side need to be replaced by covariant derivatives, and the Kronecker delta needs to be replaced by the appropriately indexed representation of the metric tensor.
Chet Miller
  • 35,124
