Is it possible to make a prediction for the eigenvalues of the Lagrangian-/action-operator of a quantum system if I know the ones of the Hamiltonian, the position- and momentum-operator?
Can I use the formula
$$ L = \sum_a \frac{1}{2} ( \dot{q}_a \cdot p_a + p_a\cdot \dot{q}_a )- H $$
to find the eigenvalues since the operators $H, p, \dot{q}$ do not commute with each other (and so they are not diagonizable with the same basis)? So the eigenvalues of $L$ are not $T-V$. Which orthonormal basis can we choose for the calculation instead?
I know that the Hamilton and Heisenberg equations also hold for this operator version (see Quantum kinematics and dynamics by J. Schwinger). So I can use
$$ \dot{q}=\frac{\partial H}{\partial p}$$
or a bit more general in terms of the Heisenberg equations:
$$ \dot{q(t)} = {\frac {i}{\hbar }}[H,q(t)]+\left({\frac {\partial q}{\partial t}}\right)_{H}$$
to reformulate the Lagrangian which then depends only on $q,p$ since $H(q,p)$:
$$ L(q(t),p(t)) = \sum_a \frac{1}{2} [{\frac {i}{\hbar }}[H,q_a(t)] \cdot p_a(t) + p_a(t) \cdot {\frac {i}{\hbar }}[H,q_a(t)]+ ]- H(q(t),p(t)) $$
But I also didn't know (with this Lagrangian) which eigenvectors I have to choose.
Since I'm studying Schwinger's quantum action principle I'm interestend in this eigenvalues because they should be minimized by the condition $\delta \hat{S} = 0$
