Our night sky is filled with stars. On a dark night a significant fraction of the sky is light. This light, we are told, has been in transit for many millions of years. There must therefore be quite a lot of light in transit at any one time.
There are many questions here where we are reminded that light has relativistic mass and therefore has a gravitational effect.
How much light is there in transit at any one time? Perhaps a measure per cubic something would be interesting.
And, of course, what gravitational effect would this light exert? Has it's effect been taken into account when the calculations of the amount of dark matter/energy is made?
Actually, on a dark night, the fraction of the sky that is light is pretty negligible. That's what it means to be a dark night ;-)
It's actually not hard to get an estimate of the density of light in the universe. Let's say that "light" includes photons of all wavelengths (not just visible light) for simplicity. A straightforward way to do it is to point a wide-spectrum telescope at the night sky and see how much fast it collects energy. (You have to point it away from the sun and other nearby sources like the galactic disc, because these sources emit a large amount of energy at Earth, which is not representative of the universe as a whole.) This was done with the COBE and WMAP satellites (and more recently Planck, with essentially the same result). They found that, if you eliminate contributions from a few specific nearby sources, the radiation in the universe follows a blackbody spectrum with a temperature of $2.73\text{ K}$. You can calculate the energy density of such a blackbody like this:
$$u = \frac{4\sigma T^4}{c} = 4.2\times 10^{-14}\ \mathrm{\frac{J}{m^3}}$$
This is just four thousandths of a percent of the critical energy density, which is
$$\Omega = \frac{3 c^2 H^2}{8\pi G} = 8.6\times 10^{-10}\ \mathrm{\frac{J}{m^3}}$$
On the other hand, the density of normal matter (atoms) is estimated to be about 4.6% of the critical density - four orders of magnitude higher. So the photon energy density is completely insignificant compared to the density of baryons, dark matter, or dark energy, and that means it has a negligible gravitational effect on the cosmological evolution of the universe.
Of course, in the vicinity of a star, the photon energy density is much higher because of the star's higher blackbody temperature. Let's take the sun, for example. The sun has a surface temperature of $5778\text{ K}$, which means the intensity of radiation it emits is
$$I = \frac{P}{A} = \sigma T^4 = 6.31\times 10^7\ \mathrm{\frac{W}{m^2}}$$
This corresponds to an energy density in the vicinity of the sun's surface of
$$u_\text{rad} = \frac{I}{c} = 0.211\ \mathrm{\frac{J}{m^3}}$$
However, the energy density of the matter that constitutes the sun is
$$u_\text{matter} = \rho_\odot c^2 = 1.2\times 10^{20}\ \mathrm{\frac{J}{m^3}}$$
So again, the gravitational effect of the photons, even on a local scale, is completely negligible.
Incidentally, this would not have been the case in the early universe, when the photons had much higher energy and thus their energy density relative to matter was much higher.
David Z
  • 77,804
Basically all starlight was produced by nuclear fusion. When fusing hydrogen all the way to the top of the binding curve at iron, about 9 MeV per proton is released. This is about 1% of the proton mass-energy, so the total relativistic mass of all the light in the universe can be no more than about 1% of the mass of the matter. This is not a complete answer, but I think it shows that this is most likely negligible when considering cosmological evolution.
I recall reading recently (do not remember where) that the mass equivalent of the photons in the universe $P_{ou}$ is about 90% due to the cosmic microwave radiation (CMR). However, the best values I found for calculating the mass equivalence of the radiation in the observable universe is based on three variables.
(1) The mass of matter in the observable universe: $M_{ou}$ = $10^{53}$ kgm. The source is
How much energy is in the Universe as photons? .
(2) The value of $\Omega_r$ = 8.24 $10^{-5}$. The source is
http://hyperphysics.phy-astr.gsu.edu/hbase/Astro/denpar.html.
(3) The value of $\Omega_m$ = 0.27. The source is the same as (2).
From these values the calculation of $P_{ou}$ is
$P_{ou}$ = $M_{ou}$ x $\Omega_r$ / $\Omega_m$ = 3.7 $10^{49}$ kgm.
Buzz
  • 364
