Quantum numbers are supposed to denote every individual orbital. But if orbital shells are probability functions, then orbitals can't be definite, solid things. So in that case, there can be variation in the amount of energy given off when an electron drops between shells - it might, say, give off a tiny little bit more energy and drop to just below the orbital shell. Isn't this possible since orbitals are just probability functions - like "Here's where the electron probably is"? Not entirely sure where I was going with this, but I think the final question is, how come quantum numbers are only ever integers?
Edit: My question is about why quantum numbers as taught in schools are always integers. "Orbitals" as predicted by the Bohr model are in fact clouds of electrons, probability functions about where an electron probably is rather than a definite statement about where it definitely is. That means there's got to be wiggle room about how far an electron can be from the nucleus.
So does that mean that quantum numbers are an oversimplification, or just averages? Or am I just misunderstanding the whole "orbitals are just probability clouds" thing?
Edit: Ugh. Right. I'm an idiot. I forgot to mention that I'm only talking about the principal quantum number, n, the one telling which orbital the electron's in.
The orbitals that you are taught about at school are energy eigenstates i.e. eigenfunctions of the Hamiltonian. For a confined system like an electron in an atom the eigenstates of the Hamiltonian have discrete and precisely defined energies so the transition energies are all precisely defined.
In the real world electron states are only approximately eigenfunctions of the Hamiltonian because an eigenstate would be time independent i.e. have an infinite lifetime. Obviously in the real world this is never the case, and as a result the energies are not precisely defined and neither are the transition energies. This causes the broadening of spectral lines called lifetime broadening.
If the particle is not confined, e.g. a free electron, the Hamiltonian does not have discrete eigenstates and the energy can have any value. In this case there are no discrete energy states.
The reason the electron position is a probability distribution is because the eigenfunctions of the Hamiltonian are not eigenfunctions of the position operator. That is, a system cannot simultaneously have a precisely defined energy and a precisely defined position. You could regard this as another manifestation of the uncertainty principle.
John Rennie
  • 367,598
Your confusion comes from unfortunate terminology
quantum numbers denote the state of a quantum system as solution of the Schrödinger equation; in particular they often refer to the eigenvalues of a maximal set of operators used to describe the physics at hand. As an example the hydrogen atom can be described by the maximal set of operators $(H, L^2, L_z)$ with respective eigenvalues (quantum numbers) $(E_n, l, m_z)$ (therefore people use to say that the state of an electron is identified by its energy and its angular momentum).
The probability functions you are mentioning are the wave functions associated to the state $|E_n, l, m_z\rangle$ defined as $\langle\,r\,|\,E_n, l, m_z\rangle$. You actually do not call this “orbital shell”, rather you call it “the wave function of the state”.
Transition between states are well-defined and happen according to some well-determined rules (in particular see the Wigner-Eckart theorem).
gented
  • 6,058
