Consider a lone photon. As its frequency increases, its energy increases. Taken to the limit, a sufficiently-high-frequency photon could be a black hole unto itself.
But the frequency of a photon is dependent on the inertial frame of the observer. Two observers could each observe this photon to be either above or below this critical frequency. Or, I could accelerate to "catch up" to this photon, red-shifting it until it is no longer energetic enough to be a black hole.
So couldn't I at one moment observe a particle to disappear beyond the event horizon, accelerate until the event horizon no longer exists, and hence observe what happened to the particle after crossing that threshold?
Is this in-principle possible? If not, why not?
EDIT: to clarify, I am not asking how much energy-due-to-photon-momentum is required to create a black hole, I am asking: given that threshold energy, how does the event horizon appear to different inertial frames which observe the photon to be above/below this threshold?
spraff
  • 5,256
