79
We're all familiar with basic tenets such as "information cannot be transmitted faster than light" and ideas such as information conservation in scenarios like Hawking radiation (and in general, obviously). The Holographic Principle says, loosely, that information about a volume of space is encoded on its two-dimensional surface in Planck-sized bits.
In all these contexts, I can take "information" to mean predictive or postdictive capability, i.e. information is what enables us to state what the outcome of a measurement was or will be (locally). But what is information, exactly? Do we have any kind of microscopic description of it? Is it just a concept and, if so, how can we talk about transmitting it?
I suspect this is probably as unanswerable as what constitutes an observer/measurement for wave function collapse, but I'd love to know if we have any formulation of what information is made of, so to speak. If I'm talking nonsense, as I suspect I may be, feel free to point this out.
ACuriousMind
  • 132,081
Mitchell
  • 1,025
6 Answers6
37
In short:
information contained in a physical system = the number of yes/no questions you need to get answered to fully specify the system.
Johannes
  • 19,343
21
Since there are already outstanding technical answers to this question, I think we should add some better philosophical underpinnings for you to explore that might help with gaining a better intuitive feel for what information is.
Warren Weaver provided an excellent discussion on information theory in 1949 in his paper entitled "Recent Contributions to The Mathematical Theory of Communication".
In the paper he breaks down communications problems into three main categories: technical, semantic and effectiveness. He further explains that the concept of information is purely derived to address the technical problem in communications theory.
A simple definition of information, provided by Weaver, is that "information is a measure of one's freedom of choice when one selects a message"; or more correctly, the logarithm of that freedom of choice. Information is thus more clearly understood as a the number of combinations of component parts that are available to be chosen arbitrarily.
In this sense, on can view it as a measure of randomness associated with a string of letters. A great example is wheel of fortune. When Pat Sajak shows you a the board with the white and green blocks, he as already provided you a lot of information by placing spaces between the white blocks, because he has drastically reduced the number of possible combinations that might be possible to fill in the white blocks.
The maximum information (or entropy) of the board with 52 boxes or "trilons" and using 26 letters is $26^{52} = 3.8\times 10^{73}$ combinations or between $244$ and $245$ bits of information in binary. However, if there were only 11 boxes illuminated white, then the actual information of the board has suddenly dropped to $26^{11} = 3.6\times 10^{15}$ combinations giving an actual information content (or entropy) or $51$ to $52$ bits. The relative information is $\dfrac{51}{244} = 0.21$ or 21%. The redundancy is then given by $1 - 0.21 = 0.79$ or 79%.
As Vanna flips boxes, she is decreasing the relative entropy and increasing the redundancy to a point where the probability of solving the puzzle becomes very high. So in this sense, information, like entropy, is a measure of uncertainty about the system.
Now there are different types of uncertainty, one is the uncertainty associated with the freedom of choice of message, and the other is noise. The uncertainty discussed in wheel of fortune example is due to the freedom of choice. In a noiseless situation, we would expect the word or phrase that Vanna unveils to be exactly the one chosen before the show. In a noisy environment, for instance, one where there is some probability of a crewmember mispelling the word while setting up the blocks, then it is possible that the final word shown is not the one chosen before the show. That uncertainty, or noise, is called equivocation, and is brought in by the environment itself.
The distinction between a noisy and noiseless environment is very important. William Tuller in 1949 published a paper "THEORETICAL LIMITATIONS ON THE RATE OF TRANSMISSION OF INFORMATION" that proved that there was no limit in the amount of information that could be transmitted in a noiseless channel. This was why Shannon's paper "Communication in the Presence of Noise" was critical to communication theory in that it properly quantified what noise actually was, and how it affected communication and the transfer of information.
Now, before finishing, it should be noted that Hartley in his 1928 paper "Transmission of Information" was the first to really give a modern definition of information and give it quantitative measure. I would recommend reviewing that paper as a starting point. Other significant contributions are made from other scientists, such as Wiener which is best captured in Cybernetics.
On a closing note, it is refreshing that the significance of quantum noise is beginning to be discussed, and I hope it continues in the future.
HDE
  • 2,977
Humble
  • 2,254
20
Information is a purely mathematical concept, usually a a characteristic of uncertainty (of a probability distribution function), but can be interpreted in different ways. In the simplest form it is introduced in information theory as a difference between uncertainties of two distributions, with uncertainty being the logarithm of a number of possible equally-probable states of a discrete random variable. For continuous distribution, it can be introduced as a logarithm of an integral. Sometimes introduced proper information - a quantity which differs from negative entropy only by a constant independent of the distribution (this constant can be taken as zero).
Thus information is a difference of proper information (difference of negative entropy) of two states. The states are represented by probability distribution functions, thus information is a formal operator of two functions.
For continuous distributions (of which discrete case is a variant) proper information of distribution $w$ is
$$I[w]=-H(w)=-\int_{-\infty}^{+\infty}w(x)\log(w(x))dx$$
and relative information of $w_2$ compared to $w_1$ is
$$I[w_2,w_1]=H(w_1)-H(w_2)=I(w_2)-I(w_1)$$
or
$$I[w_2,w_1]=\int_{-\infty}^{+\infty}\log \left(\frac{w_1(x)^{w_1(x)}}{w_2(x)^{w_2(x)}}\right)$$
This operator is not much different from norm or angle in vector spaces. It is just one measure, attributed to members of the space.
Compare this with the definition of norm:
$$||w||=\sqrt{\int_{-\infty}^{+\infty}w(x)^2dx}$$
distance
$$D[w_1,w_2]=||w_1-w_2||=\sqrt{\int_{-\infty}^{+\infty}(w_1(x)-w_2(x))^2dx}$$
angle
$$\Phi[w_1,w_2]=\arccos \frac{\int_{-\infty}^{+\infty}w_1(x)w_2(x)dx}{\sqrt{\int_{-\infty}^{+\infty}w_1(x)^2dx}\sqrt{\int_{-\infty}^{+\infty}w_2(x)^2dx}}$$
So think about information as of a mathematical quantity similar to angle.
Anixx
  • 11,524
The information is a dimensionless (unitless) - and, in this sense, "purely mathematical" - quantity measuring how much one has to learn to know something relatively to the point when he doesn't know it, expressed in particular units. Operationally speaking, it is the amount of RAM chips (or their parts) one needs to have so that they can remember some knowledge. Of course, by using the word "knowledge", I am just avoiding the word "information", and it is impossible to define any of these terms without any "circular references" because one has to know at least something to be able to define as elementary concepts as knowledge.
One bit of information is the knowledge needed to know whether a number that can be 0 or 1 with the same probability turned out (or will turn out) to be 0 or 1. In mathematics, a more natural unit than one bit is one "e-bit" which is such that 1 bit is ln(2) "e-bits". The information needed to distinguish among "N" equally likely alternatives is ln(N) "e-bits". The natural logarithm is always more natural than other logarithms - that's why it's called natural. For example, its derivative equals 1/x, without complicated constants. The formulae for the "Shannon" dimensionless information, assuming any probabilistic distribution, are given above.
In physics, every physical system with some degrees of freedom may carry some information. In quantum information, the "alternatives" are usually associated with basis vectors of the allowed Hilbert space of states. But in that context, one "bit" of information is usually referred to as a "qubit" or "quantum bit" which means that in the real world, the alternatives may also be combined into arbitrary complex linear superpositions, like the postulates of quantum mechanics dictate.
In discussions about causality, we mean that the spatially separated objects can't really influence each other. This is guaranteed by the Lorentz symmetry. In field theory, the condition is equivalent to the constraint that the space-like separated fields $\phi(x)$ and $\phi(y)$ commute with each other (or anticommute if both of them are fermionic).
Best wishes Lubos
sunspots
  • 722
Luboš Motl
  • 182,599
I recently gave a brief but but serious attempt at a different way to interpret one bit in terms of quantum physics, so perhaps it's worth mentioning that answer in the context of this much older question:
https://physics.stackexchange.com/a/91035/7670
"In terms of space, time, momentum, and matter, a single bit of information is the choice of one quantum path over another equally likely one. When applied at the level of atoms and particles, the result is a tapestry of choices that quickly becomes nearly infinite in complexity."
This definition is readily compatible with MWI approaches, as it defines the total sets of bits in the universe you can see as the "address" of your universe within the multiverse.
For better or worse, this definition is my own, not one that I'm quoting from anything. But it is nicely compatible with such simple experiments as Feynman's electron slit analysis, where photons determine the path of the electron if you get nosy about it, and so add one more bit to the definition of our observable universe.
Terry Bollinger
  • 22,299
  • 87
  • 136
This is not so difficult to answer. Consider two entangled polarised photons sent in opposite directions. There is a well defined quantum prediction for the correlation between measurements made of the two photons if the photons are entangled. Placing a single polarising filter in the path of one these photons breaks the correlation. This is all it takes to collapse the wave function. We do not need a measuring device or a sentient observer to break the entanglement. When the photon passes through the filter, its polarisation is altered. This is a clear indication the photon has interacted with the environment. We can say the entanglement has broken and the 'coherent connection" with other photon has been broken or simply state it has decohered. Some interpretations say the entanglement has not been broken. Instead, when the photon passed through the filter it interacted with thousands of atoms that constitute the filter and it has become entangled with all those atoms. As such the entanglement with its original partner has become incoherent as a result of being drowned out by all the noise from all the other entanglements. This process of particles interacting means eventually everything (except newly created particles) becomes entangled with everything else. These virginal newly created particles that have not yet interacted with the environment have a special status and can have a coherent connection to a limited amount of similar status particles.
I think when our understanding of information transfer matures we will accept that the universe has different channels of communication. Possibly the universe has an 'operating system' level of communication between coherent quantum particles that is instantaneous. This cannot be used to transmit information between macro sized objects FTL, because macro objects consist of thousands or millions of constituent particles that are all entangled with each other so no coherent information transfer can occur between macro sized objects. So when we say information cannot be transferred faster than light, we mean tangible information that can be exchanged between macro systems (e.g. sentient beings and computer systems). We should find another name for whatever is exchanged between coherent quantum particles to account for the observed correlations.
Schrodinger's cat tries to demonstrate that a macro system such as a cat can have quantum properties such as being in a superposition of being both dead and alive at the same time. In reality this would not be possible, because the cat would have to perfectly isolated from the environment such as suspending the cat in a perfect vacuum and then the cat would definitely be dead. Any sentient being or computer is necessarily a network of connected particles all entangled with each other and the environment with incoherent quantum connections. Quantum computers try to take advantage of the quantum connectivity by trying to keep particles isolated from the environment which is not easy to do.
To try and define information, one approach is to define it as quantity that relates our knowledge of the environment to the reality of the environment. When we receive (accurate) information it increases our knowledge of the environment (both past and present) and reduces the discrepancy between the reality and what we know (reduces our ignorance).
A wave function can be thought of as a statement of our ignorance of a system. Consider the following analogy. In the film "Top Gun - Maverick", tom cruise is shot down over enemy territory. The enemy are very keen to find Tom. Tom is very keen to avoid detection, because he does not find the idea of being killed or tortured very appealing. To make efficient use of their resources the enemy can draw up a map of where they think Tom most likely is and where to look first. They might start with the assumption that the fastest he can move on foot is about 10 Kph and since he been missing for about two hours they can assume he is within a radius of 20 Km from where he was shot down and draw a circle on the map. They might assume he will head for the nearest neutral border so the the circle of where he probably is, is now drawn more as an egg shape. They might consider the possibility he gets a lift with a local vehicle or if there is a train track in the area he might of jumped on a train, so they extend the area of where he might be to a a larger area extended further out along the railway line. There is also a possibility >spoiler alert< that he commandeers a jet aircraft and is making a bee-line for the nearest American aircraft carrier in the region, so they extend their probability map of where Tom is to hundreds of Km away from the crash site. Their map of where Tom might be is now effectively a wave function. Eventually an enemy pilot spots Tom making a beeline for the carrier in a commandeered jet fighter and the Tom's wave function collapses from the enemy point of view because they know where he is now. Nothing physical collapsed. The only thing that collapsed was the extent of the enemies' ignorance of where Tom was. While Tom was missing, Tom was effectively in a superposition of locations. He could be here, he could be there. In reality at any given moment Tom was in an exact location, but they were not sure where that was.
KDP
  • 10,288
