Consider the following dynamically coupled two state hamiltonian, $$H=-B\sigma_z-V(t)\sigma_x.$$Taking the eigenfunctions of $\sigma_z$ ($|+>$ and $|- >$) as basis vectors, we have the wave function to be $$\Phi=c_ 1|+>+ c_2|->$$ and we get coupled differential equations for the time evolution of these two coefficients.
$$\left[ \begin{array}{c} \frac{dc_1}{dt} \\ \frac{dc_2}{dt} \end{array} \right] = \begin{bmatrix} -B & -V(t) \\ -V(t) & B \end{bmatrix} \times \left[ \begin{array}{c} c_1 \\ c_2 \end{array} \right]$$
To decouple the equations I tried diagonalyzing the Hamiltonian involved. But, then the eigenvectors themselves involve time dependence due to $V(t)$ and thus, i'm not able to decouple the differential equations. So, is there any other method do it? Any hints are welcome.
The system can be separated, but not necessarily in nice form. For instance, the time derivative of the first eq. reads $$ i\hbar {\ddot c}_1 = - B {\dot c}_1 - {\dot V}c_2 - V {\dot c}_2 $$ Now remove $c_2$ using again the first eq., $$ c_2 = -\frac{i\hbar}{V} {\dot c}_1 - \frac{B}{V} c_1 $$ and ${\dot c}_2$ using the second eq., ${\dot c_2} = \frac{i}{\hbar}Vc_1 - \frac{i}{\hbar}B c_2$: $$ i\hbar {\ddot c}_1 = - B {\dot c_1} + i\hbar \frac{d\ln V}{dt} {\dot c}_1 + B \frac{d\ln V}{dt} c_1 - \frac{i}{\hbar}V^2c_1 + \frac{i}{\hbar} BV\left(-\frac{i\hbar}{V} {\dot c}_1 - \frac{B}{V} c_1\right) = 0 $$ Simplify, rearrange, and obtain $$ {\ddot c}_1 - \frac{d\ln V}{dt} {\dot c}_1 + \left[\frac{i}{\hbar}B\frac{d\ln V}{dt} + \frac{B^2 + V^2}{\hbar^2} \right]c_1 = 0 $$ Similarly for $c_2$.
Better way:
Change from $c_1$, $c_2$ to $$ c_+ = c_2 + c_1\\ c_- = c_2 - c_1 $$ such that the system becomes $$ i\hbar {\dot c}_+ = -V(t) c_+ + B c_-\\ i\hbar {\dot c}_- = B c_+ + V(t) c_-\\ $$ Applying the same elimination procedure for $c_-$, this time using $$ c_- = \frac{i\hbar}{B}{\dot c}_+ + \frac{V}{B}c_+\\ {\dot c_-} = - \frac{i}{\hbar}Bc_+ - \frac{i}{\hbar}Vc_- = - \frac{i}{\hbar}Bc_+ - \frac{i}{\hbar}V\left[\frac{i\hbar}{B}{\dot c}_+ + \frac{V}{B}c_+\right] = \frac{V}{B}{\dot c}_+ - \frac{i}{\hbar}\frac{B^2 + V^2}{B}c_+ $$ yields a much simpler looking eq. for $c_+$: $$ {\ddot c}_+ - \frac{i}{\hbar}{\dot V}c_+ - \frac{i}{\hbar} V {\dot c}_+ + \frac{i}{\hbar} B {\dot c}_- = 0 \\ {\ddot c}_+ - \frac{i}{\hbar}{\dot V}c_+ - \frac{i}{\hbar} V {\dot c}_+ + \frac{i}{\hbar} V {\dot c}_+ +\frac{B^2 + V^2}{\hbar^2}c_+ = 0\\ {\ddot c}_+ + \left[\frac{B^2 + V^2}{\hbar^2} - \frac{i}{\hbar}{\dot V} \right]c_+ = 0 $$
udrv
  • 10,551
  • 26
  • 35
