Is there any connection between fluctuation dissipation theorem and Kramers-Kronig relations? They are often described together under linear response theory but I do not see any exact connection (like one being special case of another).
Tomasz
  • 121
Kramers-Kronig relations can be understood as requirement that $\operatorname{Re} \chi(\omega)$ is an even function, while $\operatorname{Im} \chi(\omega)$ is an odd function - see this answer and the linked Wikipedia therein.
The general Fluctuation-Dissipation theorem usually written as proportionality between fluctuation energy spectrum and imaginary part of fourier of responce function: $$S_x(\omega) = \frac{2kT}{\omega}\operatorname{Im} \chi(\omega)$$ While the lhs of the above expression $S_x(\omega)=\langle x(\omega)x^*(\omega)\rangle$ is easily interpreted as "fluctuation" part. It is not at all obvious that $\operatorname{Im} \chi(\omega)$ is related to "dissipation". The standard derivation below uses the the Kramers-Kronig symmetry requirements and links $\operatorname{Im} \chi(\omega)$ to the dissipation of the system.
Assuming that we have the observable $x(t)$, the stochastic external force $f(t)$ and the response function $\chi(t)$ are linked via: $$ x(t) = \int_{-\infty}^{\infty}d\tau\; \chi(t-\tau)f(\tau)$$
We want to compute dissipated power $f(t)\dot x(t)$ under periodic force $f(t) = A \cos\Omega t$. To do that we first simplify the expression for $\dot{x}(t)$. Taking the derivative gives us factor $-i\omega$ and integration over $\tau$ gives a double-$\delta$ fourier transform of the cosine:
$$\dot{x}(t) = \int \frac{d\omega}{2\pi}(-i\omega) e^{-i\omega t}\chi(\omega) \pi A[\delta(\omega - \Omega) + \delta(\omega+\Omega)]$$
Integrating out the $\delta$s we'll get: $$\dot{x}(t) =-iA\frac\Omega2\left[\chi(\Omega)e^{-i\Omega t} - \chi(-\Omega)e^{i\Omega t} \right]$$
Now we multiply by $f(t)$ and average over one period:
$$\langle W\rangle = \frac{\Omega}{2\pi}\int_0^{2\pi/\Omega}dt\;f(t)\dot{x}(t) = -\frac{i A^2\Omega}{4} \left[\chi(\Omega) - \chi(-\Omega)\right] = \frac12 A^2\Omega\operatorname{Im}\chi(\Omega) $$ In the last equality we've used that real part of $\chi(\omega)$ is even, while imaginary is odd.
This links $\operatorname{Im} \chi(\omega)$ to dissipation using Kramers-Kronig relations.
Kostya
  • 20,288
