What leads us to the conclusion that spin is angular momentum? Could it not be some other quantity? Sorry if this is a rookie level question.
By treating spin as angular momentum a lot of phenomenon could be explained.
Conservation of angular momentum makes sense only if you include spin with the orbital angular momentum. Spin-orbit coupling will mix these quantities even if the system is isolated.
The algebra of the spin operators (which can be represented by the Pauli matrices) is analogous to the angular momentum algebra.
Charged systems that have an angular momentum will have a magnetic moment. They act like little magnets. The magnetic moment of electrons can be measured using Stern-Gerlach-like experiments. These experiments also elucidate the quantum nature of spin.
The idea that electrons may have an intrinsic angular momentum was theoretically proposed to explain the anomalies in the spectrum of hydrogen. It is necessary to explain the behavior of the spectrum when the atom is subjected to magnetic fields.
- The generators for spin follows the same commutation relation as that of angular momentum. i.e $$[S_{x}, S_{y}] = iS_{z}$$ obeys the similar commutation rule for angular momentum
$$[J_{x}, J_{y}] = iJ_{z}$$
The similarity in algebra is an indication why spin should be considered to be angular momentum, although it is not the complete reason.
It has been observed experimentally that spin couples to orbital angular momenta as in systems obeying $L-S$ coupling. It follows similar rules of angular momenta addition as resulting from the addition of two angular momenta. The observed spectrum in such a coupling observed matches theoretical predictions accurately if spin is considered to be angular momentum. This completes the reason why spin should be considered as angular momentum.
It gives rise to a dipole moment in case of charged objects, similar to what angular momenta does.
- 5,337
