The classical model of friction has a coefficient of friction depend only on the materials, but not area, and the force proportional to the normal force and coefficient of friction. So a given object on the same surface has the same friction whether it is supported by full bottom area or small legs as long as the materials are the same.
However every child knows that on a slide one goes faster if one lays down on their back compared to sitting on their butt. The slide is obviously still the same and since jackets usually extend below butt, the other material is also the same. So the friction should be the same as well, but it clearly isn't. So what is going on here?
Note: I mean typical stainless steel or fibreglass laminate slide, not ice, which is soft enough to complicate the matter further.
