Short answer is "no". The theory shows that heat capacities are positive. The negative heat capacities mentioned in the literature are based in misunderstandings of this theory.
For instance, the astrophysicists' argument uses the virial theorem to transform the sum of kinetic and potential energy $E=K+\Phi$ into $E= -K$ and then uses $K= \frac{3}{2} Nk_BT$ to get
$$C_V \stackrel{wrong}{=} \frac{dE}{dT} = -\frac{3}{2} Nk_B$$
which is a negative quantity, but is not the heat capacity of the system. The mistake is that the heat capacity $C_V$ is defined by a partial derivative at constant volume
$$C_V = \left( \frac{\partial E}{\partial T}\right)_V$$
The kinetic energy is a function of temperature, whereas the potential energy is a function of volume $E(T,V) = K(T) + \Phi(V)$, which means
$$C_V = \left( \frac{\partial E}{\partial T}\right)_V = \frac{3}{2} Nk_B$$
and we recover a positive heat capacity in agreement with both Schrödinger statistical mechanics theorem and with classical thermodynamic stability theory.
EDIT:
It seems my reply is being down-voted with invalid arguments such as "there is no confining volume", $(3/2)Nk_B$ is only for ideal gases, etcetera).
First, I am not considering the more general case, I am simply refutting the usual astrophysicists' argument and explaining (i) why they are not computing heat capacities, (ii) why finding regions where $(dE/dT) < 0$ does not identify systems with negative heat capacity, and (iii) why the statement "when heat is absorbed by a star, or star cluster, it will expand and cool down" is ignoring that volume is not held constant and therefore that $dQ \neq dE$.
My above answer used an abstract model, but we can be more specific. Consider the system discussed in [1]. The energy is $E = aT–b/r$, with $a = (3/2)Nk_B$ and $b$ an unspecified constant. Differentiating this energy and using the first numbered equation in [1], we obtain $dE = adT + PdV$ and a positive heat capacity for this gravitational system
$$C_V = \left( \frac{\partial E}{\partial T}\right)_V = a >0$$
D. Lynden-Bell and R. M. Lynden-Bell obtain the wrong result
$$C_V \stackrel{wrong}{=} \frac{dE}{dT} = -a$$
because they are not computing a heat capacity. Additional mistakes and physical inconsistencies in the arguments of LBLB are discussed in [2].
[1] Negative heat capacities do occur. Comment on “Critical analysis
of negative heat capacities in nanoclusters” by Michaelian K. and
Santamaría-Holek I. 2008: EPL 82(4), 43001. Lynden-Bell D.; Lynden-
Bell, R. M.
[2] Reply to the Comment by D. Lynden-Bell and R. M. Lynden-Bell
2008: EPL 82(4), 43002. Michaelian K.; Santamaría-Holek I.
