I am confused as it is written that sometimes it is true to say that heat given to a body can decrease its temperature.
Asked
Active
Viewed 134 times
It is my understanding that heat capacity and specific heat can never be negative. Now, if the question was is it possible for a system to undergo a process in which heat is added and its temperature decreases, my answer would be yes. For this to happen, the work done by a closed system would need to exceed the heat added to the system so that it's internal energy decreases according to the first law
$$\Delta U=Q-W$$
and if a change in internal energy results in a temperature decrease. That would be the case if the system was an ideal gas, because for an ideal gas, any process
$$\Delta U=C_{v}\Delta T$$.
Hope this helps.
Bob D
- 81,786
