Let be $$ P^\mu |p> = p^\mu |p> $$ i.e. $|p>$ is the eigen-vector of the 4-momentum operator.
Where does the following Lorentz-covariant completeness relation come from?
$$ \int d^4p \theta(p^0) \delta(p^2 + m^2)|p><p| = 1 . $$
apt45
  • 2,247
Two things are required to prove this. First, you haven't really defined your state $|p\rangle$ in its entirety since you haven't defined what normalization you are using for this state. In the formula above, it seems to me that you are using the normalization $$ \langle {\bf p} | {\bf p}' \rangle = \frac{2 E_p }{ 2\pi } \delta^3 ( {\bf p} - {\bf p'} ) $$ Then, the completeness relation is $$ 1 = \int d^3 p \frac{2\pi}{2 E_p } | {\bf p} \rangle \langle {\bf p} | $$ Finally, you have to show that (do this yourself) $$ \int d^3 p \frac{1}{2 E_p } = \int \frac{d^4 p}{ 2\pi } \theta ( p^0 ) \delta (p^2 + m^2 ) $$ which then implies $$ 1 = \int d^4 p \theta ( p^0 ) \delta ( p^2 + m^2 ) | {\bf p} \rangle \langle {\bf p} | $$
Prahar
  • 29,157
