Following this question: Deriving mass from simple pendulum which is summarized below
Some mass $m$ is release from rest at a horizontal position. $m$ reaches the bottom of its path (so directly under the pivot) at a velocity of $v$ m/s. And the length of the rope $l$. Now with no further information is it possible to derive an equation that can be used to describe the mass of this bob?
And the answer was of-course that the mass is independent of the motion
But I just got curious and set out to try the problem to see if I can tell something about $m$
Fixing my reference frame at the pivot, The Kinetic Energy of the earth-bob system is
$$T=\frac{1}{2}ml^2\dot{\theta}^2+\frac{1}{2}M\dot{y}^2$$
Where $\theta$ is the angle with respect to the vertical, $M$ mass of earth, $y$ displacement of earth in the vertical direction
And potential energy
$$V=-\frac{GMm}{R+y - l\cos\theta}$$
Where $R$ is the radius of earth, So by the conservation of energy
$$\frac{1}{2}ml^2\dot{\theta}^2+\frac{1}{2}M\dot{y}^2=-\frac{GMm}{R+y - l\cos\theta}$$
Solving for $m$ and taking $l\dot{\theta}=v$, at $\theta=90^\circ$
$$m=\frac{M\dot{y}^2}{[\frac{2GM}{R+y-l}-v^2]}$$
Since $$\Delta x\Delta p \geq \frac{\hbar}{2},$$ Applying it for $y$
$$M\dot{y}{y} \geq \frac{\hbar}{2},$$
So can I confidently say that
$$m \geq\frac{\frac{\hbar^2}{4My^2}}{[\frac{2GM}{R+y-l}-v^2]}~?$$
In practice The numerator is almost $0$ and the denominator too is almost $0$ since ($v^2\approx 2gh$), So mass $m$ is indeterminate which implies that it can have any value and it is true
Is my reasoning and derivation right?
Is my application of uncertainty principal right?
