I have mixed intuitions about this.
On one hand, nothing can travel faster than the speed of light and if there is enough space between you and an event then a signal will get stuck in the middle of nowhere traversing an ever-expanding void.
But, on the other hand, it seems reasonable enough that we could share information with other distant observers. That coupled with the fact that every observer has their own observable universe centered on them suggests to me that it would be possible to transmit an account of an event that another observer could never experience firsthand. While the information would have to travel farther than the radius of an observable universe, no individual particle would have to.
A diagram depicting a mediator transmitting data from an event.
Would we be able to learn about something outside our observable universe if someone sent us pictures of, for example, the cosmic background radiation of their observable universe? Is this even a possibility?
Edit: To clarify, I'm talking about an observable universe limited by the Future horizon caused by the expansion of space and not the Particle horizon caused by how far particles could have traveled given the age of the universe. As it stands right now, a mediator wouldn't be able to see anything novel since, as HDE226868 points out, our Particle horizon would have expanded to encompass the event by the time their forwarded signal would have reached us.
Edit2: Several answers have stated that any mediator would have been taken outside of our observable universe by the time it was able to transmit anything novel. But, is that going to always be the case? I was under the impression that gravity was sufficient to counteract the expansion of space to bind galaxies together. Is it unreasonable to suppose the existence of a mediator that has the appropriate velocity and acceleration to maintain a constant position relative to us for an arbitrary length of time despite the expansion of space?
Perhaps the movement of such an object has a relativistic effect on its observable universe?
Edit3: I think I figured out a good lead. While the Particle horizon is a ball around every observer and based on particles just not having had enough time to travel, the Future horizon is based on redshift which in turn is based on relative velocity among other things.
$$1 + z = \sqrt{\frac{1 + \frac{v}{c}}{1 - \frac{v}{c}}}$$
This suggests to me that two observers at a fixed position relative to each other (i.e. https://xkcd.com/1522/) will have the same Future horizon due to the Doppler effect. However, there seems to be some room to reduce redshift back from infinity with some engineering.
For instance, a telescope in orbit around a planet would be able to see farther while pointing prograde than anyone on the planet since its relative velocity to distant events would be lower and signals would be blueshifted back up from infinity. This actually seems to suggest that a mediator could peer beyond our Future horizon for us.
However, there are some other factors that go into redshift other than the Doppler effect. Gravity wells and the expansion of space also have an effect. But, would these other effects frustrate this scenario?
Psylent
  • 159
5 Answers5
Is it possible to learn about an event that occurred outside of your observable universe?
By definition, no.
The mediator in the question is a physical thing. Whether it's a human or some other contraption, it's still physical and works by the same rules as everything else in the universe. Whatever physical process happens at mediator is just another cog in the machine, so to speak. If information from "neat event" intersects with mediator's space-time point, and then eventually finds its way to you, then neat event is part of your observable universe by definition.
Whether you're talking about future horizon or particle horizon, there's no sensible way to define "observable universe" such that adding an extra space time point and calling it "mediator" allows you observe things outside the observable universe.
DanielSank
  • 25,766
The answer to this is "no." The reason for it can be seen intuitively with a bit of work, but it's not at all obvious, so I think it's a good question.
Let us first start thinking about a distant galaxy that starts out in our observable universe but then moves out of it. Later on I will introduce a mediator between these two. At first we can see the other galaxy because the light it emits eventually reaches us. However, because the universe is expanding it moves away from us over time. Eventually a distance is reached such that any light emitted from the other galaxy will never reach us, effectively because the distance is increasing faster than the speed of light.
It's worth noting that when the other galaxy passes this point it doesn't just suddenly seem to wink out of existence from our point of view. As it approaches the cosmic horizon the light it emits takes longer and longer to reach us, so that it becomes more an more red-shifted. In exactly the same way as an object approaching a black hole's event horizon (and for exactly the same reason), in principle we could always detect the galaxy if we had impossibly sensitive equipment to observe low-frequency photons, but it would appear "frozen in time" at a point just before it crossed our cosmic horizon. We cannot observe any events in the other galaxy that take place after that time.
The point of this is that the cosmic horizon is a boundary in time as much as in space, and the expansion of the universe is an integral part of the story. (Without it there would be no horizon at all.) We'll see shortly that the expansion also plays a key role in understanding why the mediator can't pass on information about what's outside our horizon.
Now let's imagine the mediator at some point between the two galaxies. Let's say it's approximately half way. Now, suppose that there is a supernova in the other galaxy just a short time after it passes our cosmic horizon. We can't observe this, but the mediator can, since the distance between the other galaxy and the mediator is only a little over half the radius of her cosmic horizon.
However, the light from the other galaxy takes a long time to reach the mediator, and space has been expanding for all that time. By the time the light from the supernova reaches her she will be much further from us. If she mediator sends us a radio signal the moment she observes the supernova, that radio signal will never reach us, because by that time the mediator sees the supernova she herself has passed beyond our cosmic horizon. To see this, note that the other galaxy was outside our horizon when the supernova occurred, and the light it emits can never pass back inside our horizon, so anything that intercepts that light must also be outside our horizon at the time.
So the resolution is that mediator can see the event outside our horizon but she can't tell us about it, because the expansion of the universe necessarily takes her outside our horizon by the time she makes the observation.
N. Virgo
  • 35,274
I know it's an old question, but maybe someone could still find it useful. First of all, let's consider a general scale factor $a(t) \sim q^t$, with $q \in \mathbb{R}$. We can work out the comoving distance: \begin{equation} \chi(t) = \int_{t_h}^t \frac{1}{a(t)} dt = \int_{t_h}^t q^{-t}dt = q^{-t_h} - q^{-t} \quad \text{if $q\neq1$} \end{equation}
so the comoving distance is bounded by above only when $q>1$. We conclude we need faster than linear growth to have a horizon. This is intuitively clear. With a cosmological horizon, there is a point where light from the far away galaxy can reach the intermediate, but not us on Earth. If the first half up to the intermediate is a comoving distance $L$, in the second half the scale factor should have changed change more than linearly so it can only travel less than $L$. This idea solved a lot of confusion for me already. Note that if we split up the integral at an intermediate $t_m$, nothing changes for the horizon, so indeed nothing changes by considering the intermediate.
For the second part I will expand on the answer by @N. Virgo, mentioning the role of redshift at the horizon. I will try to solve the following idea: As long as we can see the intermediate galaxy, it can send images from the far away galaxy, so we should always be able to see both. Surprisingly, this intuition is completely right, and explains the idea of the redshift itself! Time intervals at $t_h$ and observed at time $t$ satisfy: (cosmological redshift, see e.g. lecture notes Baumann)
\begin{equation} \frac{\lambda}{\lambda_h} = \frac{\Delta t}{\Delta t_h} = \frac{a(t)}{a(t_h)} = \frac{q^t}{q^{t_h}} \end{equation} Say we have a pulsar at the horizon, sending out regular pulses of period $\Delta t_h$. For an observer on Earth these pulses will be exponentially longer/ redshifted as $t\to\infty$. Even though we can not see farther than $\chi_{\text{horizon}} \sim q^{-t_h}$, all events really seem to freeze at the horizon. Indeed, we can always see images of the far away galaxy when we see the intermediate, and to unite this with the existence of a horizon the far away galaxy needs to be freezed in time. Light from the far away galaxy is emitted at much earlier $t_h$, so the redshifting there is a lot stronger. In practice, since the redshift happens exponentially, it will still look as if the object really disappears (see e.g. https://arxiv.org/pdf/astro-ph/9902189 for more details).
This gives in my opinion a resolution for the (purely theoretical) role an intermediate observer can play. Even though the far away galaxy never truly disappears, it will quickly become far too redshifted to observe on Earth. An intermediate observer can then make images, scale the wavelength up, and send the image to Earth. In this way, it could give us 'new' information, in the sense that the galaxy was previously lost in an astronomically long wavelength. One could imagine a chain of observers, each making an image and sending a color shifted to the next. Still, of course, any information we get will be information that was already inside the cosmological horizon.
Yes. Your observable universe keeps growing. You just have to wait around until your past light cone grows enough to encompass that event. (This answer doesn't account for universal expansion.)
Spirko
  • 1,031
If you first learn from some mediator (perhaps a "detector", who is more "sensitive" than you are) about an event (in which you didn't participate yourself)
then, thereby, you have learned about this event (learning the identities of who took part, and their indictions at their meeting) nevertheless.
This implies: If you had been more "sensitive" (or even "perfectly sensitive") you might have learned first about the event under consideration even directly yourself, and no later than you actually did through the mediator. Consequently this event is called "(in principle) observable by you"; it belonged to your "observable universe".
In turn, it is not possible to learn about an event which didn't belong to your observable universe, by definition.
p.s.
Where "speed of light" is understood here as signal front speed, regardless of whether the signal exchange is specifically "electro-magnetic", or not;
and "travel" is understood as involving the exchange of signals.
In general: You cannot say that you had learned about some particular event before you had first learned about that particular event.
It depends: signalling between each other can be possible for some pairs, but not others, and not necessarily "both ways"; cmp. "hyperbolic motion". Therefore it can certainly be imagined that there are events which don't belong to your observable universe, and that the observable universes of two participants (who are and eventually remain separate from each other, even if they may have met each other in the past) are unequal, as in your sketch.
user12262
  • 4,360
