From a video lecture on quantum mechanics at MIT OCW I found that you didn't need to know Schrödinger's equation to know the momentum operator which is $\frac{\hbar}{i}\frac{\partial}{\partial x}$. This can be derived from a 'simple' wave function of the type
$$ \psi = Ae^{i(\boldsymbol{\mathbf{k}}\cdot \boldsymbol{\mathbf{r}}- \omega t )} $$ Where we require eigenvalues for $\mathcal{\hat{p}}$ to be $\hbar k$ My questions are:
  • I understand the complex notation is for convenience. Since it's a complex exponential it'll give us a real and imaginary wave. Does the imaginary part have any physical significance? Are we to interpret this as two waves in superposition in the complex plane?
  • As we derive the expression for $\mathcal{\hat{p}}$ for this specific function, how does it guarantee that this is indeed the $\mathcal{\hat{p}}$ for every other arbitrary wave function? Can it be derived besides using the wave function I mentioned?
Weezy
  • 1,083
The momentum operator is not $-i\partial_x$, rather, that is the representation of the momentum operator on the position basis: namely $$ \langle x|\hat{p}|\psi\rangle = -i\frac{\partial}{\partial x}\psi(x). $$ Otherwise, the momentum operator is just defined by action on its eigenstates as $\hat{p}|p\rangle = p|p\rangle$.
It is not for the sake of convenience. Complex functions emerge as solutions of the Schrödinger equation (plus arguments showing that quantum mechanics cannot be done on the real numbers only).
The wave terminology is somewhat unfortunate. There are no actual waves, rather the modulus square of the solution of the Schrödinger equation can be related to the probability density of the position operator for the point particle in quantum mechanics. Remember that $\psi(x) = \langle x |\psi\rangle$, where $|x\rangle$ is the position basis and $|\psi\rangle$ is the solution of the Schrödinger equation.
how does it guarantee that this is indeed the $p$ for every other arbitrary wave function
The form of the momentum operator on the position basis can be derived using the commutation relations only. That is, if the position operator $\hat{x}$ acts on a function as $(\hat{x}f)(x) = xf(x)$ then the only operator satisfying $([\hat{x},\hat{p}]f)(x) = if(x)$ can nothing but be $(\hat{p}f)(x) = -i\partial_x f(x)$.
gented
  • 6,058
The momentum operator is the generator of shifts. In 3 dimensions ($\hbar =1$ ) \begin{equation*} (\exp [i\mathbf{a\cdot p}]f)(\mathbf{x})=f(\mathbf{x+a}) \end{equation*} Expanding in $\mathbf{a}$ \begin{equation*} i\mathbf{a\cdot p}f(\mathbf{x})=\mathbf{a\cdot }\partial _{\mathbf{x}}f(% \mathbf{x)} \end{equation*} or \begin{equation*} \mathbf{p}f(\mathbf{x})=\frac{1}{i}\partial _{\mathbf{x}}f(\mathbf{x)} \end{equation*} This does not depend on the particular $f$. In your case \begin{equation*} (\exp [i\mathbf{a\cdot p}]\psi )(\mathbf{x},t)=A\exp [i\mathbf{k\cdot (x+a}% -\omega t) \end{equation*} so \begin{equation*} \mathbf{p}\psi (\mathbf{x},t)=\mathbf{k}\psi (\mathbf{x},t) \end{equation*}
Urgje
  • 1,643
In a sense neither the real part nor the imaginary part have physical significance, as these quantities do not directly appear in observables. One way to see this is that any solution $\left|\psi \right\rangle$ to Schroedinger's equation $$ i\hbar\frac{d}{dt}\left|\psi \right\rangle = H \left|\psi \right\rangle $$ is still a solution if multiplied by an arbitrary phase $e^{i\phi}$, where $\phi$ is a constant. Multiplying this phase also preserves the normalization condition which only depends on the mod-squared of the wave-function. Since we can choose any real valued phase that does not depend on position or time, this arbitrariness is called a continuous global phase symmetry. Though this is going a little off topic, this symmetry implies (via Noether's theorem) conservation of particle number.
As we derive the expression for $\hat{p}$ for this specific function, how does it guarantee that this is indeed the $\hat{p}$ for every other arbitrary wave function? Can it be derived besides using the wave function I mentioned?
The nice derivation you gave for the momentum operator shows that plain waves are eigenstates of the momentum operator, and in this way we specify the meaning of the momentum operator. In general, states are not eigenstates of momentum but can be expanded as a superposition of such eigenstates.
dhudsmith
  • 364
