Suppose there are two positive charges $A$ and $B$, both with equal mass $m$ and the same charge quantity $q$. The initial distance between $AB$ is $R$; and the initial velocity of $B$ relatively to $A$ is $0$.
Suppose the reference coordinate system is using $A$ as the origin and $AB$ as $x$-axis; $r$ is the distance $B$ moves under the Coulomb's force
$$F(t)=\frac{q^2}{4\pi \epsilon_0\left(R+r(t)\right)^2}$$
Then I obtained the 2nd order nonlinear ODE:
$$\frac{dr(t)}{dt}=v(t)$$ and $$\frac{d^2r(t)}{dt^2}=\frac{dv(t)}{dt}=a(t)=2\frac{F(t)}{m}=\frac{q^2}{2\pi m\epsilon_0\left(R+r(t)\right)^2}$$
with initial/boundary conditions $$r(t)=0,\quad r'(t)=0$$
Questions are:
- How to find the exact solution $r(t)$ of the ODE ?
- How to find the exact solution $t(r)$ which is the inverse function of $r(t)$?
