Can anybody explain the physical difference between Dirac monopole and Polyakov monopole?
First, let me write down what I know briefly.
Dirac monopole
  1. It comes from the symmetry of Maxwell equation. By assuming that magnetic field for a point source magnetic charge $g$.
\begin{align} B(r,t) = \frac{g}{4\pi r^2} \frac{\vec{r}}{r} \end{align} Since the divergence of $B$ gives non-vanishing value due to delta function $\nabla \cdot \nabla(\frac{1}{r})=\delta(r)$. Thus we introduce the so-called Dirac String, ($i.e$, add some solenoid field)
  1. Dirac string is non-obeservable due to Dirac's charge quantization
Polyakov-'t Hooft monopole.
  1. It comes from soliton Dynamics. $i.e$ $SO(3)$ model
  2. We can compute the mass (Energy)
  3. For large distance Polyakov-'t Hooft monopole behaves like Dirac monopole
You can comment anything including above things.
This question arise from the comment of my previous question [Compact QED and Non-compact QED - Polyakov textbook ] by Stephen Powell
phy_math
  • 3,782
  1. A (generalized) 't Hooft-Polyakov monopole and
  2. a Dirac monopole with a Dirac string attached
are two types of magnetic monopoles, which differ in several ways, as OP and user ACuriousMind correctly state.
  1. On one hand, a (generalized) 't Hooft-Polyakov monopole is a regular, soliton-like, finite-energy solution to the classical Euler-Lagrange field equations of some GUT (with an action principle that extends the standard model). Its existence is unavoidable if a certain topological condition is satisfied in the GUT.
  2. On the other hand, while Dirac monopoles were mostly conceived by Dirac as a theoretical laboratory to study charge quantization, the modern interpretation is that a Dirac monopole is an effective description far away from the monopole that fails near the finite core region of the monopole. Moreover a Dirac monopole requires a non-standard action principle, cf. e.g. this Phys.SE post and links therein.
For further differences and details, see Ref. 1 and the linked Wikipedia pages.
References:
  1. F.A. Bais, To be or not to be? Magnetic monopoles in non-abelian gauge theories, arXiv:hep-th/0407197. (Hat tip: Hunter.)
