I always thought of the Uncertainty Principle as a logical consequence that follows from the Wave-Particle duality, or more precise, from the fact that all particles behave as waves as long as they do not interact with other particles.
From basic wave properties, it's clear that you cannot know both the position and the speed/impulse of a wave exactly. A strongly localized wave dissipates fast, so it has a "blurry" impulse. Moreover, a wave with an exact impulse has no precise location. So, if a fundamental "particle" behaves like a wave, then the Uncertainty Principle (for the position/impulse variable pair) is a logical consequence.
Is that correct so far?
So I wonder, why do many physicists describe the Uncertainty Principle like it was some axiom that is built into this world, and that has no reason or explanation for why it exists? There are even physicists who describe it like Nature playing masquerade. "The more we look at the position, the more Nature conceals the impulse."
No, that's not what the Uncertainty Principle is about.
The fundamental fact is that everything behaves like waves. This is the axiom, the fact without a known reason behind it. The Uncertainty Principle is just a consequence of that fact, one of the first consequences discovered by mankind.
EDIT @ACuriousMind: Well that makes sense, but I have the impression that this just shifts the discussion over to the fact that there are non-commutating operators. It's clear that if two operators don't commutate, then there's the uncertainty that is quantitatively described by the formula you wrote. But I'm still convinced that the fact that there are non-commutating operators has a qualitative reason. After all, if classical mechanics is formulated using the Hilbert Spaces tools, your inequality becomes trivial because $[A, B] = 0$ for all operators in classical mechanics.
Bass
  • 1,527
The uncertainty principle is much more general than anything you might say about the wave-particle duality. In particular, wave-particle duality is a vague and imprecise statement about how certain types of quantum systems qualitatively behave, while the uncertainty principle is a very general and quantitative statement about the standard deviations of operators.
While, in settings like the double-slit, it is true that you may think about the quantum objects as being represented by a probability wave, this breaks down whenever one considers finite-dimensional Hilbert spaces, as they occur e.g. in the setting of quantum information and its qubits. There's no continuous set of generalized position operators - not ever a position operator at all - and hence no "wavefunction". Nevertheless, the relation $$ \sigma_A(\psi)\sigma_B(\psi) \geq \frac{1}{2}\lvert\langle \psi \vert [A,B] \vert \psi \rangle\rvert$$ holds for all operators $A,B$ and all states $\psi$.
And even in the infinite-dimensional setting where you might claim that we have a "wave nature" and a "particle nature", this relation holds for all operators, not just position and momentum, and the proof just relies on basic properties of Hilbert spaces like the Cauchy-Schwarz inequality.
To stress this crucial fact: The uncertainty relation is a general consequence of the axioms that states are rays in a Hilbert space and the rule how these states give expectation values. No conception of "particle" or "wave" ever enters into the derivation, and the fact that waves also exhibit a type of uncertainty relation in their widths is a simple consequence of the properties of the Fourier transform. Since the Fourier transform is also intimately related to the position and momentum operators by the Stone-von Neumann theorem about their essentially unique representation as multiplication and differentiation, this explains the similarity without any reference to "wave-particle duality".
ACuriousMind
  • 132,081
