Let $\rho$ be the density matrix for a system and let the POVMs be $\{E_m\}$ such that $\sum_i {E_m} = I$. The probability of getting the outcome $m$ is $\operatorname{Tr}(E_m \rho)$.
The source I am reading from ( Semi definite programming to characterize quantum set , section 2.2 second paragraph ) says that the same probabilities of getting the outcomes can be obtained by performing projective measurements on a pure state (there is no restriction given on what the pure state is). That is there exists a pure state $|\phi\rangle$ ( of some arbitary dimension ) and projective opererators $\{P_m\}$ such that for every $m$ , $\langle \phi | P_m |\phi \rangle = \operatorname{Tr}(E_m\rho)$. To state it more clearly I want to prove that general POVMs can be done as projective measurements on a pure state of a larger dimension Hilbert space.
For more clarity the exact paragraph from the source I mentioned above , which I am trying to prove is
Any any general measurement on a given Hilbert space can be viewed as a projective measurement on a larger Hilbert space, and any mixed state ρ can be viewed as a subsystem of a larger system in a pure state.
I tried but can't find a way to prove the statement . I was able to prove that for POVMs for a mixed state $\rho$ can be seen as POVMs for a pure state $|\psi\rangle$ of a larger dimension ( using purification ). But I have no idea oh how to prove that POVMs on a pure state can be seen as projective measurements on some other pure state ( of some other dimension ). I am not even sure if this is the correct way to proceed.
David Z
  • 77,804
advocateofnone
  • 1,595
  • 14
  • 27
