Are you speaking specifically about currents in wires?  If you look at (the simplest version of) Ohm's law you will see that $\mathbf{J} = \sigma \mathbf{E}$, where $\sigma$ is the conductivity (technically it's a tensor, but we'll assume a constant scalar for now).  In this case, $\eta$ = $\sigma^{-1}$, which is the resistivity.  Thus, we can show that $\mathbf{E} = \eta \mathbf{J}$.
So if the current, $\mathbf{J}$, is constant, then when the resistance (= resistivity per unit length) is high, the electric field $\mathbf{E}$ should be high, if this simple approximation of Ohm's law holds.
Side Note
Generally, it is true that the electric field and current density are coupled to each other, but Ohm's law can be much more complicated.  So you should not blindly assume that when the resistance is high, the electric field will be high because of this relationship.  I make this point because in a plasma, the resistance is often supplied by the electric fields from electromagnetic and electrostatic waves acting as an effective "drag force" on the particles that are attempting to stream relative to each other.
Thus, in this case a larger resistance to flow is caused by the electric fields having a larger impact on the particles, not a larger electric field caused by a larger resistivity.
