This is a reformulation of two previous questions that seem to have been misunderstood, or most likely, I failed to make them clear. I thank all people that answered, even the belligerent ones.
Some terminology first: by classical I mean non-quantum, and I assume anybody trying to answer this questions do understand that difference. When we discuss if QM can be written in classical terms we mean a full description in terms of at least local hidden variables. Also by theory I mean what anybody means as a theory: some equations or computer algorithms written in paper, or anything equivalent to a formal system. I also assume we all know what is the difference between a theory (a simulation is also a special kind of theory) and the actual physical world.
For those unfamiliar with the violent discussions on this subject you can read this question, and this review article. Also a good popular science article with lots of references to the experimental results on oil droplets can be found here.
The question is pretty simple. The experiment on oil droplets show that what thought as a culprit of QM, the double slit interference experiment, could never be explained in classical terms. The oil droplets experiments showed that to be incorrect. Now the argument has moved to the statement that oil droplets will never be able to reproduce entanglement. Thus, entanglement is the new actual territory when we battle quantum vs. classical.
My question is not about oil droplets though. I take them as an example of a classical system that can reproduce behaviors that were previously thought to be exclusive of quantum systems.
My question is about another toy model, rule 110 cellular automata (CA). It is Turing universal thus it can simulate the behavior of any digital computer. The question is simple: digital computers can simulate entanglement and so can the 110 CA. Thus we have at least a toy model that has local rule hidden variables and reproduce entanglement.
Specific question: given this fact, what is wrong in claiming that entanglement could also be a classical phenomenon?
It seems that you're confusing, perhaps rightfully, the difference between exhibiting entangled behavior and describing entangled behavior. It's no surprise that a classical system can describe entanglement. As you point out, a digital computer can simulate an entagled system.
However, there is no meaningful entanglement happening in the computing process; it's just a classical Turing machine. I would suggest that the computer is describing an entangled behavior (given the right lens through which to process the data it produces), but it isn't exhibiting it on a level-0 physical hardware kind of way. I emphasize that it takes a certain post-processing by an observer for the computer to meaningfully be "describing" entanglement. Only a rational agent, equipped with an understanding of how to interpret the computer's output, can say "ah---there is entanglement".
A simpler example is pencil and paper. Given the right kind of observer who knows what to look for and how to interpret the output, simply writing down the Schrodinger equation seems to display entanglement if you know how to decode the "data". Perhaps a good metric here is to consider an alien species with no knowledge of our alphabet and perhaps a wildly different set of sensory organs. Such a species could look at two entangled particles and say "yes, that is entanglement", but if they look at our graphite-scribbled paper or at the weird glyphs being printed out by a computer program, they would be totally meaningless. Therefore, it seems that your assertion that entanglement "is" a classical phenomenon is a confusion between a real physical process and our understanding of it; the latter can of course be described classically, but the former is truly quantum.
As a side note, you may appreciate a chapter in David Deutsch's book "The Fabric of Reality"; I can't remember which chapter it is, but he describes "virtual reality generators", i.e. simulations, and even uses the idea to assert certain physical boundaries on reality.
danielsmw
  • 458
I can create a simulation of quantum mechanics on a classical computer, but I can't make it correctly simulate entanglement using only local data AKA local hidden variables.
That is, if I want to simulate an EPR measurement on an entangled particle at point $(x_0,t_0)$, I must use simulation data from outside the light cone region $|x - x_0| < c(t - t_0)$. Specifically I'll have to use some information from the other EPR particle at coordinates $(x_1, t_1)$ outside the lightcone from $(x_0,t_0)$, meaning $|x_1 - x_0| > c(t_1 - t_0)$.
A simulation can use this non-local data to produce correct results, but there is no local data it can track in order to reproduce real EPR correlations.
adipy
  • 709
