Let $$\langle x'|p'\rangle = N \exp(\frac{ip'x'}{\hbar})$$ be the overlap between position and momentum space, where $N$ is a normalization constant to be determined.
We can then compute $N$ by $$ \langle x'|x''\rangle = \int \mathrm{d}p'\langle x'|p'\rangle \langle p'|x''\rangle\\ \rightarrow \delta(x'-x'')=|N|^2 \int \mathrm{d}p'\exp(\frac{ip'(x'-x'')}{\hbar}) \\ =2\pi\hbar |N|^2 \delta(x'-x'') $$
see Sakurai - "Modern Quantum Mechanics" 2nd, Pearson, p. 54.
How was the factor $2\pi\hbar$ obtained? The intermediate step should look something like this: $$ \rightarrow \delta(x'-x'')=|N|^2 \int \mathrm{d}p'\exp(\frac{ip'(x'-x'')}{\hbar}) \\ =|N|^2 \int \mathrm{d}p'\delta(x'-x'') $$
But all I can think of is that one can say $\int \mathrm{d}p'=\hbar k$ where $k$ is the wavenumber.
What am I missing?
You're close, but you seem to be saying that $\exp(ikx) = \delta(x)$, which is not true, and you're missing a $2\pi$. The correct identity is
$$\int dk\ e^{ikx} = 2\pi \delta(x)$$
Therefore, with a change of variables $p=\hbar k$:
$$\int dp\ e^{ipx/\hbar} = \hbar \int dk\ e^{ikx} = 2\pi\hbar$$
Javier
  • 28,811
You can express the dirac-delta-function as:
$$\delta(x-x')=\frac{1}{2 \pi}\int dp e^{i p (x-x')}$$
(simply fourier-transform the dirac-function)
compare it with your expression and you get the factor.
p.s Your last line from intermediate step is wrong.
Qbit
