I am currently working on a (functional) analysis problem refining Pekar's Ansatz (or adiabatic approximation, as it is called in his beautiful 1961 manuscript "Research in Electron Theory of Crystals").
Anyways, I have two related questions, which the members of this community may find simple.
The Fröhlich Hamiltonian is given as follows in three dimensions
$$H=\mathbf{p^{2}}+\sum_{k}a_{k}^{\dagger}a_{k}-\biggl(\frac{4\pi\alpha}{V}\biggr)^{\frac{1}{2}}\sum_{k}\biggl[\frac{a_{k}}{|\mathbf{k}|}e^{i\mathbf{k\cdot x}}+\frac{a_{k}^{\dagger}}{|\mathbf{k}|}e^{-i\mathbf{k\cdot x}}\biggr]$$
The physical scenario here is an electron moving in a 3-dimensional crystal. Each $k$ signifies a (vibrational) mode of the crystal.
If we restrict ourselves to just a 1-dimensional crystal, why is it that the Hamiltonian can be written as follows:
$$H=\mathbf{p^{2}}+\sum_{k}a_{k}^{\dagger}a_{k}-\biggl(\frac{4\pi\alpha}{V}\biggr)^{\frac{1}{2}}\sum_{k}\biggl[a_{k}e^{i\mathbf{k\cdot x}}+a_{k}^{\dagger}e^{-i\mathbf{k\cdot x}}\biggr]$$
Namely, why do we drop the $|\mathbf{k}|$ factor in the third term?
Furthermore, I see how the creation and annihilation operators work on the (bosonic) Fock space (referring to the crystal here), especially when we write the creation operator in the form $\sum_{k=0}^{\infty}\frac{(a^{\dagger})^{k}}{\sqrt{k!}}\left|0\right\rangle =\left|k\right\rangle$. Namely, the creation operator is jumping from one tensored state in Fock Space to the next. However, I also see the form $a_{k}=\frac{1}{\sqrt{2}}\bigl(k+\frac{d}{dk}\bigr)$. How are the two forms connected? How do you intuitively think of the latter form? For example, I thought of the former form as the creation operator jumping from one state in fock space to the next, but the latter form I am not quite sure.
r.g.
  • 387
The answer to your second question is simple. For a Harmonic oscillator, the creation and annihilation operators are related to the x and p operators by (up to a choice of units):
$$ a = x+ ip $$ $$ a^\dagger = x-ip$$
Writing the x operator as $i{\partial\over\partial p}$ reproduces your formula (up to phases and signs, the above phases and signs are correct in the usual physics convensions), with p playing the role of k. The k in your formula must be interpreted as the k operator.
This is the polaron problem, which was studied heavily in the mid 1950s, after Frohlich deduced from the isotope effect that phonon electron interactions must be responsible for superconductivity. The oscillators are the phonon modes, the 1 over |k| tells you that long wavelength phonons are singular, but I don't know the answer to the first question, because the identity is superficially impossible, because one of the two forms will be dimensionally inconsistent. If you provide a reference to fix the conventions, one can decide which one is correct, and perhaps this is a simple misunderstanding. The phonons in your description have the exact same frequency, for example, which is incorrect--- the dispersion for phonons should makes the second term $\sum_k |k| a^{\dagger} a $$.
User wsc tells me that the Frohlich Hamiltonian is used to model the interactions with optical phonons. These have a flat dispersion, so the phonon part is ok as you wrote it.
