The dipole transition matrix element has a classical interpretation as the time Fourier series of the classical dipole moment of the Bohr orbit corresponding to one of the energy levels. The interpretation is only exact at high levels, at the correspondence limit, and the m,n matrix element is the m-n-th Fourier series coefficient for either orbit m or orbit n (the difference is higher order in h). This is covered in Wikipedia's page on Matrix Mechanics.
When an operator x(t) is varying in time in a stationary state, that means it has off diagonal matrix elements. On diagonal operators are constant in a stationary state. The electron is orbiting the nucleus, so the position is a function of time x(t), the dipole moment in a certain direction has Fourier components, and these Fourier components are the off diagonal matrix elements. This correspondence was the main tool used by Heisenberg to construct his matrices.
To give a simple example, the x(t) operator in the harmonic oscillator is $a+a^{\dagger}$, so it has off diagonal matrix elements purely between the state of frequency $\omega$ higher and $\omega$ lower, of magnitude about $\sqrt{n}$ (the exact relations are $a|n\rangle = \sqrt{n} |n-1\rangle$, $a^{\dagger}|n\rangle = \sqrt{n+1}|n+1\rangle$. This means that the classical x motion corresponding to the n-th state has exactly two fourier components, one of which is at frequency $\omega$, the other at frequency $-\omega$, both of size $\sqrt{n}$. This means X is sinusoidal with period $2\pi\over \omega$ of size $\sqrt{E}$, and this is indeed the classical harmonic oscillation motion.
The same holds for Rydberg orbits of the H atom, and for all off diagonal matrix elements--- they correspond to the time Fourier series of the classical quantity in the Bohr orbit version of the stationary state. They don't actually make an orbit, because a real orbit has a Fourier series which is multiples of the fundamental frequency, while the quantum system doesn't have exactly equally spaced energy levels, they are only approximately equally spaced at large N in the correspondence limit.
