For my computing project, I am creating a projectile simulator but I cant seem to get my head round the air resistance. I tried by working out the horizontal and vertical velocity by solving it (vertically and horizontally giving me two equations):
  • $dv/dt = -cv^2$ (horizontal)
  • $dv/dt = -cv^2 - g $ (vertical)
where c is 1/2 (drag co x density x cross sectional area).
But after doing the integrals and finding the equation it doesn't seem to be working as I want them to...
Sorry for the bad formatting.. (Ill try to excuse myself by saying Im new) and thanks for any help
So yeah, there are these things called vectors which represent arrows; they are made up of components. For example, we would not say "velocity (horizontal)" and "velocity (vertical)" but we would add labels $v_x, v_y$ where $x$ is usually a horizontal-label and $y$ is usually a vertical-label; then we would write the arrow as $\vec v = [v_x, v_y]$, packaging them together into this list-of-numbers that we call a "vector".
To get $\propto v^2$ drag in 2D, we form the vector:
$\vec F_{drag} = -k ~ |\vec v| ~ \vec v $
where we understand that multiplying the ordinary number $k$ over a vector $[a, b]$ produces the vector $[k~a, ~k~b]$, and the magnitude of $\vec v$, written as $|\vec v|$ or sometimes simply as $v$, is given by the Pythagorean theorem as
$v = |\vec v| = \sqrt{v_x^2 + v_y^2}.$
In other words, your equations should be:
$\frac{dv_x}{dt} = -k ~ v_x ~ \sqrt{v_x^2 + v_y^2}$
$\frac{dv_y}{dt} = -g - k ~ v_y ~ \sqrt{v_x^2 + v_y^2}$
This ensures that your drag force always points in the reverse direction from $\vec v$, and grows like $v^2$.
You can also include a wind $w$ in the $x$-direction by replacing (on the right hand side only!) $v_x$ with $(v_x - w)$. This is important because the drag force is relative to the air, not relative to the ground. With a little more effort you can draw a wind vector field $\vec w(x, y)$ and do modeling with "updrafts" and so forth.
CR Drost
  • 39,588
You made a mistake in the direction of your drag force (vector). You calculated the magnitude of this force correctly, then applied that magnitude both along your horizontal and vertical basis vectors for a total of $\sqrt{2}$ of the desired drag force, and pointing in the wrong direction!
The missing direction is given by $-\vec{v}^0 = -\vec{v} / \left| \vec{v} \right|$. So multiply your drag force magnitude by $v_x / \left| \vec{v} \right|$ for the horizontal ($x$) direction, and analogously for the vertical direction.
