I am reading Quantum Theory: Concepts and Methods by Asher Peres.
Terminology used in the book:
$P_{\mu m}$ are "transition probabilities". They are the squares of "transition amplitudes". That is, \begin{equation}| C_{\mu m}|^2 = P_{\mu m}\end{equation}
He says on page 40,
Up to this point , nothing was assumed that had any physical consequence. The phases of the transition amplitudes $C_{\mu m}$ still are irrelevant, and we could as well have stayed with the probabilities $P_{\mu m}$. It is only now that we introduce a new physical hypothesis (borrowed from classical wave theory):
Law of Composition of Transition amplitudes. The phase of the transition amplitudes can be chosen in such a way that, if several paths are available from the initial state to the final outcome, and if the dynamical process leaves no trace allowing to distinguish which path was taken, the complete amplitude for the final outcome is the sum of the amplitudes for the various paths.
Then on page 43 he says
The amplitudes $C_{\mu m}$ should be considered as the primary, fundamental object, and the probabilities $P_{\mu m}$ should be derived from them, in spite of the fact that the $P_{\mu m}$ are the only quantities that are directly observable.
My Question
I don't understand why we work with transition amplitudes instead of probabilities if the probabilities are the only direct obserables. Can someone explain why transition amplitudes are regarded as more fundamental?
The statement that "probabilities are the only direct observables" is, I'd say, an example of sloppy writing. Correlations are the other "direct observables" (one can also challenge Peres' jargon, but I am not going to to it here) which are as important as probabilities. It turns out that complex amplitudes appear to provide the most parsimonious description of the observed correlations. A nice discussion on the use of complex numbers in QM can be found in the thread QM without complex numbers.
mho
  • 75
