How much $G$ is required to bend light?. Also, please explain what happens if a powerful light beam in a vacuum is intercepted by electromagnetic fields on either sides.
HDE 226868
  • 10,934
Shiva
The equation for gravitational lensing is $$\theta=\frac{4GM}{rc^2}$$ where $M$ is the mass of the object doing to bending and $r$ is the distance of the light to the object. But $G$ is a constant - it doesn't change. The literal response, therefore, to your question is "Any positive $G$." In a universe where $G>0$, gravitational lensing is possible.
Also explain what happens if a powerful light beam in vacuum is intercepted by electromagnetic fields on either sides.
So light interacting with light? In that case, this and this should help. But this is a completely different question than your first one.
If Demosthene is correct and you mean $g$, the question sort of stays the same. We've established what $G$ must be. $M$ can also be any non-zero value - even your body bends light! It's just such a tiny influence that it's really, really, really hard to observe. And any value of $r$ will bend light, although of course as $r \to \infty$, $\theta \to 0$.
HDE 226868
  • 10,934
I'll answer the question in your headline. I suppose by "G" you mean "Gravity". If so, the answer is that any non-zero mass will cause a gravitational potential, hence deflecting the path of light. To "bend light" enough that it can be measured, depends upon 1) how close the light beam is to the mass, and 2) how precise your detector is (i.e. what is its angular resolution; for instance Hubble's resolution is 0.05 arcsec.).
In 1919, Arthur Eddington measured the deflection of the light from stars passing close to the Sun during a solar eclipse (of around 1 arcsec, I think), but you would be able to measure the effect for lighter objects if they were smaller so that the light could pass nearer the object. The angle $\theta$ of deflection is given by
$$\theta = \frac{4 G M}{c^2b}$$
where $G$ is the gravitational constant, $M$ is the mass of the object, $c$ is the speed of light, and $b$ is the distance at which the light passes by (the "impact parameter"). You see that as long as $M > 0$ (and $b < \infty$), there is a deflection, however small.
HDE 226868
  • 10,934
pela
  • 10,767
