10
  1. I'm asked to show that $$\frac{d(\hat{A}\hat{B})}{d\lambda} ~=~ \frac{d\hat{A}}{d\lambda}\hat{B} + \hat{A}\frac{d\hat{b}}{d\lambda}$$ With $\lambda$ a continuous parameter. Should I use the definition $$\frac{d\hat{A}}{d\lambda} ~=~ \lim_{\epsilon \to 0} \frac{\hat{A}(\lambda + \epsilon) - \hat{A}(\lambda)}{\epsilon}$$ applied to $\hat{A}\hat{B}$ like $$\frac{d(\hat{A}\hat{B})}{d\lambda} ~=~ \lim_{\epsilon \to 0} \frac{\hat{A}(\lambda + \epsilon)\hat{B}(\lambda + \epsilon) - \hat{A}(\lambda)\hat{B}(\lambda)}{\epsilon}$$ and do some algebra to get the RHS of the first equation, or I'm missing something?
  2. Another interesting derivative to pay attention to is: $$\frac{d}{d\lambda}\exp(\hat{A}(\lambda) )~?$$
J L
  • 2,947
$$A(\lambda+\epsilon)B(\lambda+\epsilon) = (A(\lambda) + \epsilon \dot{A} )(B(\lambda) +\epsilon \dot B ) = A(\lambda)B(\lambda) + \epsilon(\dot AB+A\dot B) + o(\epsilon^2)$$
20
Here we will only consider the added last subquestion (v4):
$$ \frac{d}{d\lambda}e^{\hat{A}} ~=~ \int_0^1\!ds~e^{(1-s)\hat{A}}\frac{d\hat{A}}{d\lambda}e^{s\hat{A}} .\tag{1}$$
The identity (1) follows by setting $t=1$ in the following identity
$$ e^{-t\hat{A}} \frac{d}{d\lambda}e^{t\hat{A}} ~=~ \int_0^t\!ds~e^{-s\hat{A}}\frac{d\hat{A}}{d\lambda}e^{s\hat{A}} .\tag{2}$$
To prove equation (2), first note that (2) is trivially true for $t=0$. Secondly, note that a differentiation wrt. $t$ on both sides of (2) produces the same expression
$$e^{-t\hat{A}}[\frac{d}{d\lambda},\hat{A}]e^{t\hat{A}}~=~e^{-t\hat{A}}\frac{d\hat{A}}{d\lambda}e^{t\hat{A}},\tag{3}$$
where we use the fact that
$$\frac{d}{dt}e^{t\hat{A}}~=~\hat{A}e^{t\hat{A}}~=~e^{t\hat{A}}\hat{A}.\tag{4}$$
So the two sides of eq.(2) must be equal. $\Box$
Here are hints for 2: Note that $e^{\hat{A}(\lambda)}=\sum_{n=1}^\infty \frac{\hat{A}(\lambda)^n}{n!}$ and in the interest of preserving order that $\frac{d}{d\lambda} \hat{A}(\lambda)^n=\sum_{k=0}^{n-1} \hat{A}(\lambda)^k \frac{d\hat{A}}{d\lambda} \hat{A}(\lambda)^{n-k-1}$. Using these facts, and the beta function fact $B(n,k) = \frac{n!(k+1)!}{(n+k+1)!}=\int_0^1 x^{n-1}(1-x)^k dx$, through some sum swapping, index changing, and factorial rewriting you can arrive at "Sneddon's formula" for $\frac{d}{d\lambda}e^{\hat{A}(\lambda)}$. All these details can be found in "Mathematical Methods of quantum optics" by Ravinder Rupchand Puri, the beginning of chapter 2.
polpetti
  • 101
