65
It's my understanding that when something is going near the speed of light in reference to an observer, time dilation occurs and time goes slower for that fast-moving object. However, when that object goes back to "rest", it has genuinely aged compared to the observer. It's not like time goes slow for a while, and then speeds back to "normal," so that the age of the observer once again matches the object. The time dilation is permanent. Why wouldn't the same thing happen with length contraction? Since the two are so related, you'd think if one is permanent, the other would be also. And from everything I've read so far, length contraction is not permanent. An object will be at rest touching an observer, go far away near light speed, return to touching the observer, and be the same length it was at the beginning. It shortens, and then grows long again, as if its shrinkage was an illusion the whole time. Did I just not read the right things or what? Were my facts gathered incorrectly?
HDE 226868
  • 10,934
14 Answers14
43
Time dilation is a comparison of rates. When an object is moving fast with respect to you, it's clock rate is slow, and when it comes to rest with respect to you its clock rate returns to normal. The time difference between the two clocks at this time is due to the accumulation due to these different time rates. That is the leftover effect of the time dilation but not the time dilation itself.
Length contraction, like time dilation, exists when there is relative motion and goes away when there is no relative motion, but there isn't any "accumulation" with length contraction, so there is nothing to be "left over".
21
The way I see it, time dilation is the real effect here.
Length contraction (in SR) is just a consequence of the fact that the "length" of a rod is the distance between simultaneous positions of the rod's endpoints. But two observers with different velocities will have different ideas about what simultaneous is, and this means they measure different lengths.
The best paradox to think about here is the "ladder" or "train" paradox. I think if you have got your head around that you understand length contraction.
Ben Cotterell
  • 211
According to the 'something', it is the observer's clock that runs slower and it is the observer's rulers that are contracted. That is to say, the time dilation and length contraction are symmetrical. Neither clock can be objectively said to be running slow and neither ruler can objectively said to be contracted.
Now the symmetry is lost; the object's accelerometer registered non-zero acceleration for some time while the observer remained inertial. This means that there is now an objective difference between the object (non-inertial) and observer (inertial) and, thus, an objective difference in elapsed times.
In fact, in SR, acceleration of an extended object must be handled with great care. If an object is to not to stretch or compress during acceleration, different parts of the object must have different (proper) acceleration.
See, for example, this question for additional information and links.
There is actually an equivalent to "total elapsed proper time" along time-like curves in spacetime (which can represent the worldlines of particles moving slower than light), and that is the "proper distance" along a space-like curve (which cannot be any real particle's worldline). See the spacetime wikipedia article for more on time-like vs. space-like, particular the basic concepts section dealing with different types of intervals in special relativity, and the spacetime in general relativity generalizing that discussion.
The simplest physical interpretation of proper time on a time-like curve is just the total elapsed time on an ideal clock that has that curve as its worldline. But just as an arbitrary curve can be approximated as a polygonal shape consisting of a series of straight segments connected at their endpoints, so an arbitrary time-like curve can be approximated as a series of short inertial segments, which could represent bits of the worldlines of a bunch of different inertial clocks which cross paths with one another at the point the segments join. Then if you add the time elapsed by each inertial clock on each segment, this is approximately the proper time on the whole curve. Analogously, an arbitrary space-like curve can be approximated by a series of space-like segments, and the endpoints of each segment can be events at either end of a short inertial ruler which is moving at just the right velocity so that its plane of simultaneity is parallel to the the segment. Then the total proper distance is just the sum of the proper length of the rulers for all the segments. But this will probably only make sense if you already have a decent familiarity with spacetime diagrams in special relativity.
To give a mathematical example, suppose we are dealing with curves in SR which can be described in the coordinates of some inertial frame, and suppose the curves only vary their position along the x-axis so we can ignore the y and z space coordinates, and just describe the curves by some x(t) function. Then a time-like curve is one where $\frac{dx}{dt} < c$ everywhere, and a space-like curve is one where $\frac{dx}{dt} > c$ everywhere. If the time-like curve is approximated by a "polygonal" path made up of a series of inertial segments that each have a constant velocity $v$ over a time-interval $\Delta t$ in the inertial frame, then the elapsed proper time on each segment is $\sqrt{1 - v^2/c^2} \Delta t$ (this is just the time dilation equation), and the total proper time along the whole polygonal path is the sum or the proper time for each each segment. In the limit as the time-intervals become infinitesimal, this sum becomes an integral, and in this limit the error in the polygonal approximation goes to zero, so the actual proper time along the curve is $\int \sqrt{1 - v(t)^2/c^2} \, dt$.
Similarly, the space-like curve can be approximated by a polygonal path made up of a series of space-like segments whose endpoints have a spatial interval of $\Delta x$ between them, and with each segment having a constant value of $v^{\prime} = \frac{dx}{dt}$, where $v^{\prime} > c$. Each segment will be parallel to the simultaneity plane of a ruler moving at a slower-than-light speed $v = \frac{c^2}{v^{\prime}}$, and if the ruler's ends line up with the endpoints of the spacelike segment, that means the ruler has a contracted length of $\Delta x$ in the inertial frame we're using, which means the ruler's proper length is $\frac{1}{\sqrt{1 - v^2/c^2}} \Delta x$ (this is just the length contraction equation). So the total proper distance along the polygonal path is just the sum of the proper length for each ruler, and in the limit as the rulers' proper lengths become infinitesimal the sum becomes an integral and the error goes to zero, so the actual proper distance along the curve is $\int \frac{1}{\sqrt{1 - v(t)^2/c^2}} \, dx$.
So, you can see that in the first integral for proper time the factor in the integral is the same one that appears in the time dilation equation $dt_{proper} = \sqrt{1 - v^2/c^2} \, dt$, and in the second integral for proper distance the factor in the integral is the same one that appears in the length contraction equation $dx_{proper} = \frac{1}{\sqrt{1 - v^2/c^2}} \, dx$.
Hypnosifl
  • 6,240
Length contraction effects may be permanent in the same way as time dilation! You just have to choose the right example.
Example: An astronaut is traveling at v=0,99 c to an exoplanet, according to Earth frame he is traveling 198 light years in 200 years. According to his frame (reciprocal gamma = 0,141) he is traveling 27,9 light years in 28,2 years. After his arrival on the exoplanet, he is permanently younger than (and outliving) his twin brother on Earth, and he is permanently at a distance of 198 light years from Earth, a distance which he could never have traveled without length contraction.
Moonraker
  • 3,173
Putting CuriousOne's comment into an answer,
In the theory of relativity, time dilation is an actual difference of elapsed time between two events as measured by observers either moving relative to each other or differently situated from gravitational masses. Wikipedia
I see that such a definition might be misleading as it talks about time dilation in an "elapsed time" sense. Although I can't say it is technically wrong, perhaps a better way to understand it would be in terms of speed that time goes at for observers moving relative to each other.
Just like length contraction, time dilation, interpreted as difference of speed of time flow also disappears as the observers again come at rest relative to each other. But, the elapsed time is a cumulative quantity. That difference can't be restored. Total time or any such concept may not be covered by General Relativity or any such present theory, as far as my limited knowledge goes.
Cheeku
  • 2,455
  • 34
As you say, time dilation and length contraction occur when two frames of reference (observer and observed) travel at two different speeds. Both of these effects "go away" if the two frames of reference subsequently travel at the same speed; that is, time will pass at the same rate and two yardsticks will have the same length.
But the EFFECTS of these relativistic effects are permanent in BOTH cases. For time dilation it's easy to imagine (i.e. the "old twin" scenario that you mentioned). So here's an example for length contraction:
Imagine that there's an immense opaque disc between you (on Earth) and a big stellar nebula. The disc is big, but not so big that it completely obscures the nebula. Some of the photons coming from the nebula are blocked by the disc.
Now imagine that the same scenario, but the disc is travelling very fast tangentially to you and the nebula. In other words, it's moving across your field of vision. Now, at such immense distances, you won't be able to easily see the disc moving, but it WILL be length-contracted. So fewer photons from the nebula will be blocked by the disc, allowing you to see more of the nebula.
This is a permanent effect! Those extra photons that slipped by the foreshortened disc are now streaming out into the universe, interacting with things and hitting retinas (maybe yours) long after the disc slows down (relative to you).
Nothing that happens in the universe every really "goes away". I didn't even mention the increased mass of the disc, which will distort the paths of those photons and everything else around it. Every distortion is "permanent" in that respect.
TheGerm
  • 121
Time dilation does disappear as relative velocity approaches zero. The things experienced during the time experienced do not disappear; cells which have died remain dead and second hands which have ticked ahead do not reverse direction. To undo those things would require time reversal.
Sine we as humans only perceive time in one direction, time reversal is irrelevant: if an object is travelling in direction a at 1m/-s we would perceive and record it as travelling in direction -a at 1m/s, or direction a at -1m/s. We always record and perceive time as forward moving, but it can as easily be seen in the other direction.
No, your facts weren't gathered incorrectly, your reasoning is just incorrect. It doesn't even take knowledge of physics to answer the question, just logical reasoning. (Don't take my language as a personal insult, I'm just trying to be clear.)
"It's not like time goes slow for a while, and then speeds back to "normal," so that the age of the observer once again matches the object."
Well, actually, yes, time does go back to "normal" when the moving clock comes back to rest. (All relative to the observer, of course). Once the clock comes to rest, it will once again tick at its normal rate, which is faster than the rate it ticked at when it was moving.
The clock will be behind, however, because it spent some time being a slowpoke. Your idea that once the clock begins to tick at its normal rate it will somehow "catch up" with the other clock is incorrect.
That's like saying if one marathon runner spends an hour walking, while his competitor runs, once he starts running again, he'll immediately catch up to the other guy. No, he'll be behind because of the time he spent walking while the other guy was running. Same idea with the clocks.
anotherguy
  • 250
Time dilation and length contraction are effects that occur when two observers move relative to each other. They both are zero when the observers are in the same inertial reference frame. While they exist, the effects are entirely reciprocal, so both observers see lengths contracted and time running slowly in the other frame. Neither is permanent- they both vanish if the observers stop moving relative to each other.
The permanent effect on the respective ages of the twins in the twin paradox is not a result of time dilation, but of the changing reference frames of the travelling twin, which shifts the traveller's plane of simultaneity. On both legs of the journey the travelling twin sees the stationary twin's clock running more slowly than their own.
Length contraction is caused by the two ends of a rod accelerating in different ways. If a one-meter rod starts moving to the right, with the left end and the right end accelerating in exactly the same way (that is, with the acceleration $a(t)$ the same for each end at each time $t$) then the rod does not contract (in its original rest frame). If it decelerates in the same way, then it does not change length at that end either.
To take an extreme but entirely illustrative example, if both ends of the rod instantaneously jump from speed 0 to speed .9, then the entire rod is going to travel at speed .9, and it is going (according to any observer on earth) to be the same length while traveling that it always was. If it decelerates just as uniformly, then when it stops it will still have that same length.
Things look different in the frame of the moving rod, because the accelerations of the two ends, if they are simulataneous in the earth frame, cannot be simulataneous in the moving-rod frame (and vice versa). If both ends accelerate simulataneously in the earth frame, then the right end accelerates before the left end in the moving frame, causing the rod to stretch in that frame. When it comes to a halt, if the deceleration is simulataneous at both ends in the earth frame, the left end decelerates before the right end, causing the rod to contract and return to its original length.
If the accelerations are such that the movng rod maintains its original length in the moving frame, then it must be shrunk in the earth frame. The ratio of the two lengths is always determined by the Lorentz factor, but the Lorentz factor does not tell you you anything at all about the ratio of either of these lengths to the length of the rod before it was moving.
So your question is based on a false premise. When a rod starts to move, it might (in the earth frame) either contract, expand, or maintain its original length. When it stops, the same is true. What happens depends on the details of the acceleration/deceleration. As to "why" it expands or contracts, the answer, in its entirety is that it expands or contracts because (and only if) one end starts moving before the other. Likewise when it stops.
You don't need relativity to see that this has to be what happens in the earth frame. You only need relativity to predict what happens in the moving-rod frame --- but your question is not about that!
WillO
  • 18,387
Time dilation and length contraction is a property relative to the reference frame, not to the object.
This is clear, because the object can have different lengths according to different observers, so the shortest length cannot be "memorized" by the object, since it is not something that happens to the object itself, but in how it is seen by different observers. Therefore, the object does not experience anything permanent, but is only as different observers see it.
Davius
  • 1,700
Imagine a room. Inside that room we place a cube in the middle. And then we walk around the room, observing the cube from diffrent angles.
We don't ever say that "the cube has been length contracted" because we understand that the act of walking around the room is causing us to see the cube from diffrent angles and thus, some of its sides will become shorter or longer than others...
In special relativity that's the same thing. When we accelerate in space, we perform a hyperbolic rotation in spacetime. Spacetime has 4 dimensions so when we do perform that rotation, we ultimately observe reality from a diffrent point of view.
We see objects differently because we "walked around in spacetime". The object itself never changed.
Now, time dilation is not constant either.
If I travel close to the speed of light, I have slowed myself down in time which means that
  1. From my perspective: the clocks of others have sped up
  2. From the perspective of someone else: my clock has slowed down
When we come back down to the same speed, and compare clocks they will disagree. But that doesn't mean that the same spacetime intervals haven't passeed for us!
Because I will ultimately realize, that I had aged just as much as my friend has back at Earth, I just didn't experience it... So there is no paradox...
Just like when you put something in the freezer, it stays "young" for longer, time still passed the same for you and for your beef in the freezer... It just stayed that way for longer...
That's the same but in a 4d spacetime, you keep track of events not by counting seconds (cuz now time is relative) but by counting spacetime intervals.
So eitherway there is no paradox!
Nuke
  • 117
-3
Any change in time at all is only "permanent" because of the second law of thermodynamics and the resulting arrow of time.
Señor O
  • 7,882
