While reading a text book about basics of Quantum Mechanics, I came across a situation in which it is said that
$E=\hbar\omega$ and also
$E = \frac12mv^2=p^2/2m$
where
$h$ Planck's constant
$\hbar=\frac{h}{2\pi}$ Planck's reduced constant
$\omega=2\pi f$ angular frequency
$m$ mass
$v$ velocity
$p$ momentum
But if I take the first definition,E=(h/2pi)*w,then
E=(h/2pi)*2*pi*f (because w=2*pi*f)
 = h*f
 = h*(v/λ)       (because v=fλ)
 = p*v           (de-Broglie's wave-particle duality p=h/λ )
 = mv*v          (because p=m*v, the momentum)
E = m*v^2
This is not same as definition $E=\frac12mv^2$.
What am I missing in the derivation above?
gmax
  • 69
The relationship $$ v=\lambda\nu=\frac{\omega}{k} $$ describes the phase velocity ($v_p\neq v$) and not the group velocity ($v_g=v$), so it should be $$ v_p=\frac{\omega}{k}=\frac{\hbar\omega}{\hbar k}=\frac{E}{p}=\frac{p}{2m}=\frac{v}{2}\tag{1} $$ which does follow from the de Broglie relation ($p=h/\lambda=\hbar k$). Inserting (1) into your 3rd line gives $$ E=pv_p=mvv_p=mv\left(\frac12v\right)=\frac12mv^2 $$
Kyle Kanos
  • 29,127
