For a project, I'm planning to study Bell's inequality, which as far as I can gather is taken to rule out hidden variable theories of QM. I'm looking for recommendations of decent sources which derive the inequality, so I can get my head around the assumptions made and exactly where the inequality is applicable. I should add that I'm not looking for a "general outline" kind of source, I need something a bit more rigorous!
glS
  • 15,488
  • 42
  • 114
Lammey
  • 633
Here is a simple and rigorous description. It says nothing about how and why QM sometimes gives results that are incompatible with hidden variables, but it makes it completely clear what it is that hidden variables can't do.
Understanding Bell's Theorem
The theorem is about explaining the statistics observed by two experimenters, Alice and Bob, that are making measurements on some physical system in a space-like separated way. The details of their experiment are not important for the theorem. What is important is that each experimenter has two possible settings, named 0 and 1, and for each setting the measurement has two possible outcomes, again named 0 and 1.
[....] Having their settings and outcomes defined like this, our experimenters measure some conditional probabilities $p(ab|xy)$, where $a,b$ are Alice and Bob’s outcomes, and $x,y$ are their settings. Now they want to explain these correlations. How did they come about?
Well, they obtained them by measuring some physical system $\lambda$ (that can be a quantum state, or something more exotic like a Bohmian corpuscle) that they did not have complete control over, so it is reasonable to write the probabilities as arising from an averaging over different values of $\lambda$. So they decompose the probabilities as
$p(ab|xy)=\sum p(\lambda|xy) p(ab|xy\lambda)$
The first assumption that we use in the proof is that the physical system $\lambda$ is not correlated with the settings $x$ and $y$, that is $p(\lambda|xy)=p(\lambda)$. I think this assumption is necessary to even do science, because if it were not possible to probe a physical system independently of its state, we couldn’t hope to be able to learn what its actual state is. It would be like trying to find a correlation between smoking and cancer when your sample of patients is chosen by a tobacco company.
And so on. Each probability step is simple and logical.
J Thomas
  • 3,146
Bell's inequality is essentially a triviality, so I'm not sure what you mean by a "derivation".
Let $A,B,C$ and $D$ be random variables.
Whenever $A=B$ and $B=C$ and $C=D$, it follows that $A=D$. Therefore the probability that $A=D$ must be at least the probability that ($A=B$ and $B=C$ and $C=D$).
What steps do you feel are missing there?
WillO
  • 18,387
Take a look at Modern Quantum Mechanics by J.J Sakurai.
This is a good graduate level Quantum mechanics textbook by Wiley that has a discussion and derivation of Bell's inequality in sec.3.9 entitled "Spin Correlation Measurements and Bell's Inequality" beginning on pg. 223.
The discussion uses the Dirac bra/ket formalism and addresses issues of locality.
-1
There are detailed discussions of the assumptions of theorems about locality in these papers:
https://arxiv.org/abs/1709.10016
https://arxiv.org/abs/2003.03395
The short summary is that Bell's theorem assumes that the system that sets what measurements will be done and the measured system are not correlated, that the measured and measuring systems evolve locally and that the systems are described by stochastic variables (random numbers).
One particularly important circumstance in which Bell's theorem does not imply non-locality is that it quantum physics is local as long as you don't modify its equations of motion with collapse:
https://arxiv.org/abs/quant-ph/9906007
https://arxiv.org/abs/1109.6223
Quantum systems are described by observables represented by Hermitian operators not by stochastic variables so Bell's theorem doesn't imply the non-locality of quantum theory. The paper above also gives an explicit account of how Bell correlations arise as a result of local interactions between the measured system, measurement devices and decoherent systems carrying measurement results.
alanf
  • 11,359
  • 16
  • 33
