63
I know what anti-matter is and how when it collides with matter both are annihilated. However, what about anti-photons? Are there such things as anti-photons?
I initially thought the idea preposterous. However I am curious because, if anti-photons don't exist, then anti-matter could theoretically transfer its energy to normal matter - through the mechanism of light. Is it right?
Dale
  • 6,150
5 Answers5
49
Well, they do and don't. Depends on your point of view. Here's the story.
Quantum field theory requires for consistency reasons that every charged particle has its antiparticle. It also tells you what properties will the anti-particle have: it will have the same characteristic from the point of view of space-time (i.e. Poincaré group) which means equal mass and spin. And it will have all charges of opposite sign than a matter particle.
If the particle is not charged then QFT doesn't impose any other constraint and so you don't need antiparticles for photons (since they are not charged). But you can still consider the same operation of keeping mass and spin and swapping charges and since this does nothing to photon, you can decide to identify it with an antiphoton. Your call.
Marek
  • 23,981
18
The short answer to "are there anti-photons" is "yes", but the disappointment here is that anti-photons and photons are the same particles. Some particles are their own antiparticles, notably the force carriers like photons, the Z boson, and gluons, which mediate the electromagnetic force, the weak nuclear force, and the strong force, respectively. Particles that are their own antiparticles must be electrically neutral, because an aniparticle has the opposite electrical charge as its partner particle. Other things must also be zero, like the number of quarks. A neutron cannot be its own antiparticle because it is made up of quarks and an antineutron is made up of antiquarks. A $\pi_0$ is made up of a quark and an antiquark and is in fact its own antiparticle also.
You can find lots out about particles at the particle adventure(http://particleadventure.orghttp://pdg.lbl.gov), part of the Particle Data Group's web site( ).
Henry
  • 404
Photons are simply their own antiparticles, but aren't called antphotons.
A subatomic particle that is its own antiparticle is called a "Truly neutral particle". It remains itself under the charge conjugation. All charges: electric, magnetic, color, flavor etc, must be zero.
Positronium, the bound state of an electron and a positron (e−, e+) is also truly neutral, so two photons colliding (two photon physics) can produce a positron and an electron. Or other composite particles that are truly neutral, like a proton antiproton, which requires a lot of energy. (I believe particle accelerators can't provide, but it happens in cosmic rays.)
Remember though that photons do not really collide (at least this is extremely rare). Pair production is a little more complicated than that and happens near a nucleus.
Although the photons behave almost as if real, they are technically virtual.
Physics question from University Illinois. Is that anti-photons and photons are the same particles. Some particles are their own antiparticles, notably the force carriers like photons, the Z boson, and gluons. As they have electrically neutral charge. Where as other characteristics like spin and such...
https://van.physics.illinois.edu/ask/listing/1153
-13
It is my understanding that antiparticles are the opposites of each other such as electron positron pair -- which means the positron is an electron flipped 180 degrees on its axis --same angular velocity, same size but PHOTONS are not particles, they are electromagnetic waves which rotate 360 deg for every wavelength so in effect are "positive" 50% of time and "negative" 50% of the time as they move forward so each "photon" impulse is its own anti"impulse" half the time
Dew1
