21
In comments to a Phys.SE question, it has been written:
'Tunneling' is perfectly real, even in classical physics. [...] For sufficiently large temperatures this can put the system above a hump in its potential energy.
and
the only difference between the classical case and the quantum mechanical one is that classical physics is a random walk in real time, while QM is a random walk in imaginary time.
I understand that in a system of particles with finite temperature some particles can overcome a potential barrier. That's how I interpret the first statement. I don't understand the business of "random walk in imaginary time". Can someone explain?
Update
What I was originally looking for was 1.) classical system that can transport mass through a forbidden region and 2.) explanation of "random walk in imaginary time". So far, I don't see anything for question 1.), but I think I'll grok 2.) if I invest some time and energy.
garyp
  • 22,633
8 Answers8
11
Frustrated total internal reflection is an optical phenomenon. It's such a close analogue to quantum tunneling that I sometimes even explain it to people as "quantum tunneling for photons". But you can calculate everything about it using classical Maxwell's equations.
Steve Byrnes
  • 17,082
There are two ways to see the analogy between the "quantum diffusion" and classical diffusion. The first one, I think the easier one is comparing the Schrödinger equation with the diffusion equation: $$i \partial_t \psi = -\sum \partial_{xx} \psi$$ (forgetting all the $\hbar,m$ factors) When you transform $t \to -i \tau$ you get the usual diffusion equation $$\partial_\tau \psi= \sum \partial_{xx} \psi$$ The diffusion equation is precisely the one which governs the probability distribution of a random walk so we can say the quantum propagation is a random walk (or rather diffusion) in complex time. But I don't really think this gives a clue why tunneling should happen with both.
The second way is through the path integral. It was derived even before Feynman or Dirac in 1923 by Wiener that we can formulate the random walk transition probability $P(x_0,x_1,T)$ from $x_0$ to $x_1$ in time $T$ as $$P(x_0,x_1,T) = \int \exp(-S_0[x(t)]/\xi) \mathcal{D}[x(t)],\; S_0[x(t)] = \int_0^T \frac{1}{2} \dot{x}^2 d\tau$$ With $x(0)=x_0$ and $x(T)=x_1$ and $\xi$ a parameter of the random walk. When we substitute $t \to -i\tau$ we will have three $i$ in the action - two in the time derivative and one in the action. In the end we get the Feynman path integral $$\int \exp(iS_0[x(t)]/\xi) \mathcal{D}[x(t)]$$ But same as the wave-function, the propagator isn't the same object as the transition probability - it has to be squared. Once again - quantum propagation is kinda like a random walk in complex time (but not entirely).
Now to a classical analogue of tunneling. Suppose you have a small charged particle in a fluid and an electrostatic potential blocking it from entering and area with a potential barrier $V$. I say it is charged so that the quasineutral fluid is not affected and we can focus only on the particle but a general case would work similarly. The particle has an average kinetic energy $3 k_B T/2<V$ from the molecules bouncing off from it. But even though there seems not to be enough energy in the surroundings, there is a non-zero probability it will cross the barrier because the particles can "bounce it through" even though with some difficulty.
This is analogous to the quantum particle which can never be found to have an energy larger than $V$, yet you find it on the other side. Maybe not surprisingly, this bouncing of a particle in a fluid is modeled as a random walk with a diffusion equation.
Void
  • 21,331
Consider the path integral:
$$\int Dx \exp\left(i\int\left(\frac{m\dot{x}^2}{2}-V\right)dt\right)$$
You can consider paths in "imaginary time" by performing a Wick rotation $t\to i\tau$
$$\int Dx \exp\left(-i^2\int\left(\frac{m}{2}\left[\frac{1}{i}\frac{dx}{d\tau}\right]^2-V\right)d\tau\right)$$
$$\int Dx \exp\left(\int\left(\frac{m}{2}\left[\frac{1}{i}\frac{dx}{d\tau}\right]^2+V\right)d\tau\right)$$
So we're now considering a classical action $S[x]=\int\left(\frac{m}{2}\left[\frac{1}{i}\frac{dx}{d\tau}\right]^2+V\right)d\tau$.
The potential has been inverted. Where we had, for example, a double well potential, we now have a double "hump" potential. There is a classical trajectory associated with going from one hump to the other i.e. it rolls down the hill into the centre, and then up the other hill coming to a stop at the top. But this path is in imaginary time (the instanton solution).
The path integral lets us calculate the probability of the particle travelling from one position to another over some, here imaginary, time. a particle will move around space like a random walk with these probabilities.
Can somebody perhaps be more formal/give a more in depth explanation? This is a little vague I realise...
BMS
  • 11,733
Michael
  • 341
As for "a classical analog to quantum mechanical tunneling", theoretically one can jump over a classical barrier having lesser kinetic energy than the potential energy one's mass would have at the top of the barrier. In fact, in the course of a high jump, one can bend over the barrier in such a way that one's center of gravity will be outside of the body and pass under the barrier. See, e.g., A. Cohn, M. Rabinowitz, Classical Tunneling, Int'l Journ. Theor. Phys., v. 29, #3, 1990, p. 215.
If you prefer a strictly one-dimensional classical analog, you can imagine a train of masses connected with springs, which passes a one-dimensional potential barrier - again, if the thickness of the barrier is less than the length of the train, the latter does not have to have the kinetic energy equal to or greater than that of its total mass at the top of the barrier. However, the high jumper example seems more graphic.
akhmeteli
  • 27,962
The last part of @Void's answer is spot on. The magic words are "Kramer's escape rate problem". See: https://home.icts.res.in/~abhi/notes/kram.pdf
This phenomenon occurs when a classical particle is both confined to propagate in a local potential energy minimum and placed in an ambient thermal bath. The particle can "tunnel" out of the potential energy well, despite not having enough deterministic kinetic energy of its own, due to the thermal fluctuations of the bath. As in the case of quantum tunneling, the probability that the particle escape its potential energy well is proportional to the negative exponential of the energy "height" of the barrier. The fact that this phenomenon is not called "thermal tunneling" is just historical accident/Copenhagen propaganda.
Evanescent waves are the mechanism beind both quantum tunneling and frustrated total internal reflection in @SteveB's answer. Evanescent waves and frustrated total internal reflection are not limited to light, but can occur in any phenomena governed by the wave equation, including sound and water waves.
I'll address question (1) in OP's question, namely whether there is classical 'tunneling' in the sense that mass is transported through a classically forbidden region. The answer is yes.
In classical electrodynamics, a charged particle can pass through a barrier even when it's initial kinetic energy is lower than the height of the barrier. I will give an example from Griffiths' Introduction to Electrodynamics:
Consider a particle of charge $q$ and mass $m$, approaching the finite barrier $$ U(x) = U_0\left[ \Theta(x)-\Theta(x-L) \right] $$ from $x=-\infty$, with $v(-\infty)=v_i$ and $v(+\infty)=v_f$. The force is then $$F = -\frac{\mathrm{d}U}{\mathrm{d}x} = U_0\left[-\delta(x)+\delta(x-L)\right]. $$
The motion of the particle satisfies the differential equation due to radiation reaction: $$ a(t) = \tau \dot{a}(t)+\frac{F}{m}, \quad \tau = \frac{\mu_0q^2}{6\pi mc}. $$
This radiation reaction when acted on by a force changes the nature of the particle's motion fundamentally. Solving the DE, we know the final and inital velocities are related by $$ v_i = v_f -\frac{U_0}{mv_f}\left[1-\frac{1}{1+(U_0/mv_f^2)(e^{-T/\tau}-1)}\right], $$ where $T$ is the time it takes to pass through. Choose the final kinetic energy (after passing through the barrier) $K_f = \frac{1}{2}mv_f^2 = \frac{1}{2}U_0 $, and $L=\frac{1}{4}v_f\tau$, we can calculate the initial energy to be $$ K_i = \frac{1}{2}mv_i^2 = \frac{8}{9}U_0 < U_0. $$ Also, $T = \tau\ln(4/3) \in \mathbb{R} $, so we know it indeed passes.
Jonathan Huang
  • 964
  • 14
In the case of complex velocity, there is not only a tunnel effect, but also heat transfer from a cold to a hot body. This is due to the fact that the real part of the velocity square may become negative $(Re V+iImV)^2=(ReV)^2-(ImV)^2+2iReV ImV$. The imaginary member of the complex number is compensated by the complex conjugate member. This is the effect of complex speed. This corresponds to the turbulent flow regime. $$\frac{\partial T}{\partial t}+V_k\frac{\partial T}{\partial x_k}=\chi \Delta T+\frac{\nu}{2c_p}(\frac{\partial V_i}{\partial x_k}+\frac{\partial V_k}{\partial x_i})^2$$
For a large imaginary part of the velocity, the real part of the last term may be negative. At real speed, he describes heating of the body by changing the speed. At complex speed, it describes the cooling flow. It may happen that the de-negative part of the velocity square will cool the cold environment. This is Ranque-Hilsch effect. The existing thermodynamics describes only the real velocities of the medium; in the case of a complex velocity, deviations from the laws of thermodynamics are possible
