Time dilation calculated using Schwarzschild metric for a non rotating spherical body is: $$t_0=t_f\sqrt{1-\frac{2GM}{rc^2}}$$
For such a non rotating spherical body, what would the time dilation of a clock in vacuum free-falling from infinity be? (If the answer is non-trivial; a high level outline of the calculation would suffice / be appreciated)
Edit: I am currently working on an iOS app that is trying to model the mechanism underpinning relativity. So, far the mechanism that I have created is shockingly simple and shockingly good at conforming to Relativity. However, I am trying to break it. I am trying to find any possible areas where the two may diverge. I have noted that using my model a clock in freefall will experience no time dilation, i.e. $t_0=t_f$ and I want to make sure Relativity agrees.
I have noted the gravitational component of time dilation above. Since my clock is moving one might also expect a kinematic time dilation. I can calculate the velocity of my clock: $$E_k=\frac{1}{2}mv^2$$ $$E_p=\frac{-GMm}{r}$$ $$v=\sqrt{\frac{2GM}{r}}$$ Plugging this velocity into the kinematic time dilation equation: $$\Delta t'=\frac{\Delta t}{\sqrt{1-\frac{v^2}{c^2}}}$$ $$\Delta t'=\frac{\Delta t}{\sqrt{1-\frac{2GM}{rc^2}}}$$
At this point one might make the observation that the kinematic dilation is the inverse of the gravitational dilation and therefore conclude that: $$t_0=t_f$$
aepryus
  • 1,021
This is how to calculate the time dilation for an object moving at velocity $v$ in a radial direction towards or away from the black hole.
Because the object is moving radially $d\theta = d\phi = 0$ and the Schwarzschild metric simplifies to:
$$ c^2d\tau^2 = c^2\left(1-\frac{r_s}{r}\right)dt^2 - \frac{dr^2}{1-r_s/r} \tag{1}$$
$d\tau$ is the proper time, and this corresponds to the time shown on the falling objects clock. $dt$ and $dr$ and the time and radial displacement measured by the distant observer. The time dilation is $d\tau/dt$, and to calculate this we have to note that if the velocity measured by the Schwarzschild observer is $v$ then $dr = vdt$. Substituting this into equation (1) we get:
$$ c^2d\tau^2 = c^2\left(1-\frac{r_s}{r}\right)dt^2 - \frac{v^2dt^2}{1-r_s/r} $$
And rearranging this gives:
$$ \left(\frac{d\tau}{dt}\right)^2 = 1 - \frac{r_s}{r} - \frac{v^2}{c^2}\frac{1}{1-r_s/r} \tag{2} $$
I've left $v$ in the equation. To eliminate $v$ you need to use the expression relating $v$ to $r$ for an object free-falling from infinity:
$$ \frac{v}{c} = - \left( 1 - \frac{r_s}{r} \right) \left( \frac{r_s}{r} \right)^{1/2} $$
I'll leave the working as an exercise for the reader. The rather surprising result after we've done the substitution is:
$$ \frac{d\tau}{dt} = 1 - \frac{r_s}{r} \tag{3} $$
John Rennie
  • 367,598
Simpler:
A constant of motion for an inertial observer in the Schwarzschild metric: $$ \left(1 - \frac{r_s}{r}\right)\frac{dt}{d\tau} = \frac{E}{mc^2}\ .$$
For an observer starting at rest at infinity then $E/mc^2=1$, so $$ d\tau = \left(1 - \frac{r_s}{r}\right) dt$$
Thus, on a very fundamental level, a clock in freefall experiences time dilation, whether it starts from rest or not.
ProfRob
  • 141,325
