I have the following problem:
Suppose a test particle is radially freely infalling towards the Schwarzchild radius (r=2M). Suppose the particle is sending out a monochromatic electromagnetic signal out to $r=\infty$. The observer at infinity measures a redshifted wavelength $\lambda_{\infty}$ such that $$\lambda_{\text{particle}} \sim \lambda_\infty e^{-t/k}$$ where $k$ is a constant when the test particle is very close to crossing the horizon. Express $k$ in terms of the mass of the black hole.
Attempt at a solution: The frequency redshift for the Schwarzchild metric is $$\frac{\omega_1}{\omega_2} = \frac{(1-2M/r_2)^{1/2}}{(1-2M/r_1)^{1/2}} = \frac{\lambda_2}{\lambda_1}$$
Where $M$ is not the proper mass. I'll be taking $r_1 \to \infty,$ so $$\lambda_\infty (1-2M/r_2)^{1/2} = \lambda_{\text{particle}}$$ I need this in terms of $t$ so I look at a null geodesic: $$0=-(1-2M/r)dt^2 + (1-2M/r)^{-1}dr^2$$ $$(dt/dr)^2 = (1-2M/r)^{-2}$$ $$\Delta t = \pm \int_{r_1}^{r_2} (1-2M/r)^{-1}dr = \pm (2M\ln(r-2M)+r)\Big|_{r_1}^{r_2}$$ $$\Delta t =(r_1 -r_2) + 2M\ln \frac{r_1 -2M}{r_2 - 2M}$$
I'm not really sure how to take it from here. I don't understand how to change the expression involving $r_1,$ and $r_2$ into one involving $t.$ Any help would be appreciated.
Jbag1212
  • 2,958
The problem can be solved by deriving a correct expression for $\lambda_{\infty}(r)$. Then by differentiating with respect to $t$ we get $$\frac{d\lambda_\infty}{dt}=\frac{d\lambda_\infty}{dr}\frac{dr}{dt}.$$
If the right hand side is $\propto \lambda_{\infty}$ as $r \rightarrow r_s$, then I think you have your answer.
ProfRob
  • 141,325
