47
Apparently Huygens' principle is only valid in an odd number of spatial dimensions:
Why is this?
[EDIT] This is somewhat perplexing, since AFAIK it's pretty common to teach freshmen about double- and single-slit diffraction using a two-dimensional analysis and invoking Huygens' principle. Does this work only because there's an ignored third axis of translational symmetry?
I wonder if it's possible to gain insight by making a grid and doing sort of a finite-element analysis.
You should look at the form of the advanced fundamental solution of D'Alembert equation, built up in geodesically convex open sets including the source localized at the event $y$ and the test point localized at the enent $x$ receiving the wave generating by the source. The construction, at least for analytic manifolds with analytic metrics, is obtained by summing a nice series originally discovered by Hadamard (and handled by Riesz actually; there is indeed a wonderful paper in French by Riesz about this fantastic construction nowadays relating the heat kernel theory with QFT in curve spacetime). Hadamard-Riesz' results have been extended to the smooth case by sevaral modern authors (see Guenther's and Friedlander's textbooks). The series, if the dimension gives rise to a fundamental solution containing a term which is completely supported on the light cone emanating from $y$. Therefore, referring to this term only, the solutions of D'Alembert equation emitted by $y$ propagates along null geodesics to reach $x$ from $y$. This basically is Huygens' principle.
If the dimension is even and the manifold is not flat or the dimension is odd, further terms appear added to the one localized on the light cone. The underlying "mathematical phenomenon" is more or less the same, in flat spacetime, when adding a mass to D'Alembert operator thus passing to the Klein-Gordon equation which does not obey Huygens' principle.
The relevant point is that this further term is now supported inside the future light cone emanating from $y$. In this case there is a contribution to wave solutions emitted by $y$ propagating along timelike geodesics from $y$ to $x$, and Huygens' principle fails.
This is a more detailed version of @tparker's answer.
Suppose $\phi(x,t)$ is a spherically symmetric solution to the wave equation satisfying the initial conditions
$$\phi(x,0)=0$$ $${\partial \phi \over\partial t}(x,0)=f(x)$$
Then we have:
Theorem 1: If the number of dimensions is odd, $\phi(x,t)$ is completely determined by the values of $f$ on the past ``light cone'' of $(x,t)$.
Theorem 2: If the number of dimensions is even, $\phi(x,t)$ depends on the values of $f$ both on and inside the past light cone of $(x,t)$.
More precisely, let $M(x,t)$ be the mean value of $f$ on the sphere of radius $t$ around $x$. Then Theorems 1 and 2 follow from:
Theorem 1$'$: If the number of dimensions is odd, $\phi(x,t)=t M(x,t)$.
Theorem 2$'$: If the number of dimensions is even, then $$\phi(x,t)=\int_0^t s M(x,s) / \sqrt{t^2-s^2} ds$$
So in evenly many dimensions, the mean value of f on every sphere of every radius from $0$ to $t$ contributes to the solution, while in oddly many dimensions, only the sphere of radius $t$ contributes. In particular, in evenly many dimensions (but not in oddly many) an initial disturbance at the origin can have effects at $x$ long after the initial wave crest has passed.
Theorems $1'$ and $2'$ are not too difficult to prove, but it might be more illuminating to consider the underlying intuition. Namely:
Given initial data for (say) a 2-dimensional wave, we can create initial data for a 3-dimensional wave by using the same data and making it independent of the third coordinate, which I'll call $z$.
Now if we solve the 3-dimensional problem, we should get a solution independent of $z$; restricting to the plane, we've solved our 2-dimensional problem.
Under this operation, if our initial data are concentrated near the origin for the 2D-problem, they'll be concentrated all along the $z$-axis for the 3-D problem. So from every point along the $z$-axis, we get an expanding 3-dimensional sphere of non-zero wave.
Now consider a point $P$ in the plane. Every one of our vertical array of expanding spheres will eventually pass through point $P$. That's why there will be ongoing non-zero wave values at point $P$ (and explains exactly why it's everything inside the past light cone, not just on the light cone, that matters at a given event).
WillO
  • 18,387
I think this originated with Hadamard and his Method of Descent. See Lectures on Cauchys Problem in Linear Partial differential Equations--starting on page 7. His results were that waves in two dimensions did not propagate sharply, but had a wake (a tail, ..). Eg. a circular wave propagating in two dimensional space vs. a spherical wave propagating in three dimensional space where it would propagate cleanly without a wake.
Hadamard essentially took a slice through a cylindrical wave in three dimensions to get a circular wave in two dimensions (descending one dimension). People have taken propagating without a wake to be one criterion in satisfying Huygens Principle.
So this is the origin of 'why', if you accept Hadamard's results.
user45664
  • 3,136
Huygen's principle is basically equivalent to the fact that the Green's function $G(s)$ for the wave equation only has support at $s = 0$, where $s$ in the invariant spacetime interval. In other words, signals can only propagate exactly on the light cone and not inside the light cone - they travel at the speed of light/sound without leaving a "wake" behind them. The fact that this property only holds in odd spatial dimensions is a fairly straightforward exercise in complex contour integration, demonstrated e.g. in https://link.springer.com/article/10.1007%2FBF02903572.
tparker
  • 51,104
