17
I've always wondered (and was re-inspired to explore further from these two videos) that if at a single point of time we know about the complete state (position, momentum, spins, everything.) of every particle in an isolated system (e.g., the whole Universe), can we perfectly determine its future? And by same analogy, also the past?
I understand that according to the uncertainty principle, it is impossible to determine all state properties of a particle accurately at the same time.
So my question is, is it like future of an isolated system is already determined but is just not perfectly predictable by an observer because of limitations in observability?
UPDATE: To be more clear, the question is not about whether we can or can not determine the future but about whether or not the future of an isolated system is already fixed. I.e., given exactly same initial conditions, will two isolated systems always be in same state with time? Is our future already fixed even though we'll never know it in advance?
UPDATE: Would appreciate less technical and more accessible explanations. I'm not from Physics background but am interested in it nonetheless.
6 Answers6
16
There are a few ways to answer your question, and I will try to list some of them.
  1. According to Quantum Mechanics, and due to the Heisenberg Uncertainty Principle, we cannot predict the future state (position and momentum) of any system. Given the state of a system in classical phase space $(\textbf{r}(t_0), \textbf{p}(t_0))$, we cannot determine the state at some later time $t$. However, given a quantum state $ | \Psi (\textbf{r}, t_0)\rangle$, we can use Schrodinger's equation $i \hbar \partial_t | \Psi \rangle = H | \Psi \rangle$ to predict the state's evolution. The difference here is we are tracking the probability of the system being in some classical state$^1$, not which state it will be in.
  2. Unfortunately, we do not have a "theory of everything" at the moment, only effective theories that cover certain domains (specifically, certain energy domains and length scales). Even if we were given the quantum state of the Universe, we wouldn't have the physics to determine its time-evolution. In some sense, we may never arrive at such a theory, and only have better and better effective theories that cover a wider range of natural phenomena.
Edit: It's important to note that quantum mechanics doesn't make any philosophical arguments about the observer's role in nature. It isn't that we don't have enough information to know exactly where the particle is or what its momentum is at some future time. It's that the particle doesn't even have a well defined position or momentum until we measure it. What happens when we interact with the particle is currently up for interpretation by different interpretations, and there is no definitive answer at the moment.
Edit 2 (Less technical explanation): It's difficult to answer your question in a nontechnical way because we need to define what you mean by "perfectly determine [the Universe's] future." Remember, by the uncertainty principle, it is impossible to determine the exact position and momentum of a particle. So, I'm assuming you mean that we begin with the complete quantum state of the system in question. All we can do we this state is determine the probabilities of each particle having a position/momentum within some range of values. Theoretically, yes, we can determine the future quantum state of the system (and thus the future probabilities). This is my answer in part 1. In part 2, I explain that our current understanding of the Universe is incomplete. At the moment, we use our best estimates of a Theory of Everything would look like. However, these estimates only cover certain areas of physics, and some are incompatible at the moment (e.g., General Relativity and Quantum Field Theory). In this sense, we cannot determine the future, even if we had access to the current state of the Universe.
$^1$ Specifically, by "tracking the probability of the $\ldots$ classical state," I mean that given the quantum state $ | \Psi (x, t_0)\rangle$ at some time $t_0$, we can use Schrodinger's equation to determine the probability of the particle being located between some $x$ and $dx$ (or between $p$ and $dp$ in momentum space) at $t_0 + \Delta t$. The probability is given by
$$ P = \langle \Psi (x, t_0 + \Delta t)| \Psi (x, t_0 + \Delta t)\rangle dx. $$
Ultima
  • 1,311
A deterministic universe need not be predictable. And even a deterministic universe not hampered by any limits to observability need not be predictable.
As an example take a toy universe consisting of an infinite chain of $0$'s and $1$'s. This 1D cellular universe evolves according to cellular automata rule-110: the state of a cell becomes $1$, unless the current value of the cell and its right neighbor are both equal to $0$, or if the current value of the cell and both its neighbors are all $1$s. It goes without saying that this 'universe' is fully deterministic with each of its discrete states being defined with zero uncertainty.
It has been proven that such a 'rule-110 universe' is capable of universal computation. Now we can ask the question: can this universal computation capability be deployed to predict the future states of this cellular universe? In other words: is there a shortcut within the rule-110 universe that allows it to anticipate its own future state?
The answer is 'no'. The universal computation capability does not provide a shortcut. The fastest route to get to generic future states is to 'play out the full evolution' and predictions are not possible within this rule-110 universe.
Added following the update to the question: a question like "Is our future already fixed even though we'll never know it in advance?" can be meaningful only when operationalized. This means that the term "fixed" needs to be defined in a way that allows us to test if our future is "fixed". The only viable way to do this is to interpret the question "is our future fixed?" as being synonymous to "do the laws of physics allow us - at least in principle - to predict our future?". The above 'rule-110 automata reasoning' indicates the answer to that question to be "no".
Johannes
  • 19,343
Even in a quantum universe, all evolution is deterministic if interpreted under Many-Worlds interpretation. So all possible futures could be "already determined", but you would still be unable to know which of those futures will be directly experienced by your qualia, since qualia experiences are always described by non-unitary probabilistic projection operators.
Without getting into quantum physics (because it's not really going to change the conclusion I draw), even if you assume that the evolution and unfolding of a system in space-time is governed by deterministic laws and that the laws are posed in the form of differential equations, you still run into an issue.
The first thing to note is that differential equations do not define outcomes. They define trends. They don't tell you where you're going, but only which way you're going. To know where you're going, you also have to know where you were to begin with.
To get full determinism for outcomes means also having complete information on the boundary conditions or (specifically) the initial conditions for a given dynamics. In the Universe, as a whole, this would be presumably given - at any given place & time in space-time - by the contents located at and within the intersection of the past light cone of that point-instant with the time zero hypersurface of the Big Bang. So, that's a sphere that lies on the time zero surface.
As time goes on, that sphere gets larger and more and more of what was initially outside of it comes to be inside of it. Consequently, even in a system governed by a deterministic dynamics, the future is not a strictly logical consequence of the past, because not all information that was available at a later space-time point-instant was available to the earlier space-time point-instant.
A larger and larger portion of the initial hypersurface comes into view with the passing of time. That's a strict increase, over time, in the total information content that underlies your current state.
The only way you're going get determinism out of that is if the contents of the initial hypersurface have the property that the knowledge of what lies in even the tiniest parts of the hypersurface gives you complete knowledge of what lies in it all.
NinjaDarth
  • 2,850
  • 13
In quantum mechanics the outcome of measurements is in general not determined when given the exact physical state of the system in general. But apart from the uncertainty arising from this, the future is as determined as is the present. If the entire solar system were to be put in a big perfectly isolated box, then you could in principle perform a measurement to determine who is the US president in the year 2017. This measurement would collapse the wavefunction of the box such that it would evolve exactly toward the measured outcome.
If $O$ is an observable, then to measure this observable in the state that lies a distance t into the future, you would need to measure the observable $\exp\left(\frac{i H t}{\hbar}\right)O\exp\left(-\frac{i H t}{\hbar}\right)$ in the current state.
Count Iblis
  • 10,396
  • 25
  • 49
-4
The universe cannot be predicted from a single data point about a moment in time because inertia does not exist in any one moment but is critical to how a system would develop.
