What is the difference between single mode and multi mode optical fibres? First off, I guess that by modes we mean the spatial modes of the electric (or magnetic?) field right?
Now: what makes a fibre able to support more than a single mode? I mean, what aspect of its structure corresponds to which mode(s) can be transmitted?
SuperCiocia
  • 25,602
It's simply the diameter of the fiber core. In a single-mode fiber, only the lowest-order mode fits physically into the fiber.
ptomato
  • 4,354
You can assume either electric or magnetic field for simplicity, they both are present in light as it's electromagnetic wave.
Now, mode is a sustainable pattern in the fiber optic cable. Imagine waves on a string, only the integral multiples of half wavelengths effectively form a mode. Let there be a complex output pattern at the output of a string. It turns out if we aren't playing with it continuously, it will be essentially periodic, maybe long period. And we can always reduce it via fourier transforms to a sum of some basic modes. Imagine the output at the end of a MMF(multi mode fiber) as waves on a string with intensity output as the wave amplitude on the string. It may be complex. But you can simplify the output by considering it as a sum of several modes. You can play with waves on a string here. It won't do a fourier transform though. http://phet.colorado.edu/sims/wave-on-a-string/wave-on-a-string_en.html
The concept is a little different for SMF and MMF. In case of SMF, Ray theory fails and light propagates as a wavefront as explained here: Single-mode fibers and ray-theory of light
Harshfi6
  • 477
The V-number defines the mode of any fiber. It depends on wavelength, diameter of fiber and refractive index.
The v number is
\begin{align} \ V^2 &= \frac{2}{} (_1^2−_2^2)\\\\ \end{align}
Each mode has an effective index that can be defined by: \begin{align} \ _ = _ \frac{2}{}\\\\ \end{align}
The effective index tells you how tightly the mode is confined to the waveguide core
  • Guided mode _ < _ < _
  • Tightly confined to the core _ ~ _
  • Weakly confined to the core _ ~ _
  • Unguided or radiating modes _<_
Haris
  • 710
