I have read ray-theory cannot be applied to single-mode fibers. Why?
I know rays are kind of an approximation to describe the real behavior of light, and electromagnetic theory and photonics are closer to nature, but are there no "rays" in single-mode fibers?
Thank you.
baister
  • 273
The fibres are too small (10um) for light to behave like a ray, you need the wave equation.
Ray theory works when: (size of all dimensions in system)*(relative error tolerance) >> (wavelength of light).
For macroscopic objects this is usually true.
In a double slit experiment/demonstration, where ray theory fails, we combine a smallish slit size with a sensitive angle measurement to bring out the wave effects of light.
In a single mode fibre the core diameter is only ~15 times larger than the infrared 1um light (shortened to about 0.75 um due to refraction) that is passing through it. This means that you can't have rays bounce off the sides like you could in a wider fibre. The only way to pass light (of the given wavelength) is to have the wavefront propagate directly down.
Kevin Kostlan
  • 6,875
  • 25
  • 36
The one reason behind this is Interference! The bouncing light rays interfere constructively or destructively which affect the propagation through the fiber.
If you want to go one step further, at the scale of optical fibers and using lasers, the coherence length of the light allows for these interference to happen between the waves before and after "bouncing" on the fiber.
Anael
  • 355
