Planck's Law is $$I(\nu,T)=\frac{8\pi\nu^3}{c^2}\cdot\frac{1}{e^{h\nu/kT}−1}$$
This solves the UV catastrophe. For higher frequencies, intensity goes to zero.
It does so because of $e^\nu$ not because there is a $h$ constant. If we remove $h$ parameter from the equation, it still goes to zero for higher frequencies. Right?
So why is "UV catastrophe is solved by quantization" said?
Note: I'm not saying if h = 0. I'm saying if there was no h constant. Like this:
$$I(\nu,T)=\frac{8\pi\nu^3}{c^2}\cdot\frac{1}{e^{\nu/kT}−1}$$
user50322
  • 781
By omitting $h$ from the formula you are just setting $h = 1$, so it's still the quantum mechanics description, just with a different value of $h$.
If you don't include quantum mechanics the expression you get is the Rayleigh-Jeans law:
$$ I(\nu,T)=\frac{2\nu^2kT}{c^2} $$
The two laws agree for small $\nu$ because for small $\nu$:
$$ e^{h\nu/kT} \approx \frac{h\nu}{kT} $$
and in this limit Plank's law reduces to:
$$ I(\nu,T) \approx \frac{8\pi\nu^2kT}{hc^2} $$
which is the same as the Rayleigh-Jeans law give or take a multiplicative constant.
John Rennie
  • 367,598
You must not have read carefully the links I gave in answer to your previous question.
The difference between getting a classical formula for a cavity radiator or a quantum mechanical formula lies in the fact that the photon energies are not continuous, that is what quantization means. Planck assumed quantization to get the formula.
Published in 1900, it originally described the proportionality constant between the energy (E) of a charged atomic oscillator in the wall of a black body, and the frequency (ν) of its associated electromagnetic wave. Its relevance is now integral to the field of quantum mechanics, describing the relationship between energy and frequency, commonly known as the Planck relation: planck relation
So h is the quantization constant with the appropriate units to get the relation above, i.e. that a quantized harmonic oscillator emits energy in packets given by the formula. This assumption fitted the data and tied well with the photoelectric effect.
The number is not arbitrary, it depends on the system of units, and it can be 1. In high energy physics theories often c=h=1 is assumed and when one wants to get real numbers one has to untangle the units. Setting h to 1 does not negate quantization, it just changes the units.
anna v
  • 236,935
It doesn't make any sense to just remove $h$, because the units are then incorrect ($h$ has units of action). The question as stated is unanswerable.
Putting aside the ridiculous attempt of user50322 for normalizing Physics Units System to make h=1. He still makes a point when he keeps nagging about Plank Law not being a discrete math equation.
(8π(ν^3)/c^2) / (Exp(hν/kT)-1) is a continuous function with a singularity when ν=0. It does not indicate just by itself the quantum nature of light. It may be said that it is the result of a probability distribution that makes unlikely that very high frequency photons be emitted by a hot black body.
The explanation user50322 is looking for is that : For a large ν, a hν energy amount is difficult to reach for the oscillators (atoms) of a black body at any given high Temperature T. In other words, the random disturbance commotion originated by the Temperature in the walls of the black body has a low probability of energizing any of its oscillators at at-least hν if ν is large, and if the oscillator is short of hv, no photon will be emitted (there the quantization of the damn thing), so just a few photons are emitted at a large frequency ν in comparison with a not so large frequency.
The black body walls will have very few regions where by chance the commotion accumulates energy that surpasses hν.
