With $[x,p_x]=i\hbar $, how to determine the form of the operator $p_x$?
Well, it doesn't need to have any form before you choose a representation for the operators.
In general, any Hermitian operator $Q$ satisfying $[Q,\psi]={\cal F}$, is the generator of the transformation $\psi \rightarrow\psi + i\epsilon{\cal F} $.
Let's try to figure this out. Consider the action of the unitary operator $U(\epsilon)=e^{i\epsilon{\cal Q}}$ on the operator $\psi$, $$U(\epsilon)\psi U^{\dagger}(\epsilon)=\psi+i\epsilon{\cal F}+{\cal O}(\epsilon^2) $$ Expanding and comparing terms with $\epsilon$, you will get $[Q,\psi]={\cal F}$. That's why $Q$ is the generator of the transformation $\psi \rightarrow\psi + i\epsilon{\cal F} $.
In your case, $[x,p_x]=i\hbar$ means that $p_x$ is the generator of the transformation $x\rightarrow x+\epsilon \hbar$. If one chooses the coordinate representation, any function $f$ of the coordinate $x$ transform in the way, $f(x)\rightarrow f(x+\epsilon\hbar) $
Thus you can write an explicit form of the transformation in this way, $$U(\epsilon)f(x) U^{\dagger}(\epsilon)=f(x+\epsilon\hbar)= e^{\epsilon\hbar\frac{d}{dx}}f(x)=e^{-i*i\epsilon\hbar\frac{d}{dx}}f(x) $$ where $U(\epsilon)=e^{i\epsilon p_x}$. In the last expression, you can identify $p_x$ in coordinate representation is $-i\hbar \frac{d}{dx}$.
Of course, $[x,-i\hbar \frac{d}{dx}]=i\hbar$.
I hope that this helps you understanding the operator language.
- 387
Using Fourier analysis, and setting $\hbar$ to 1 (I leave it to you to reintroduce it consistently using dimensional analysis), we have $$ f(x) =\int \tilde f(k) e^{ikx} dk\\ xf(x) = \int i \frac{\partial \tilde f(k)}{\partial k} e^{ikx} dk $$ where we used integration by part. Applying the commutation relation holds $$ i (\frac{\partial( p_x[\tilde f(k)])}{\partial k} -p_x[\frac{\partial \tilde f(k)}{\partial k}]) = i\tilde f(k) $$ where $p_x[]$ means the operator applied to the inside of the bracket. Here its representation in $k$ space. As the right hand side of this equation contains no derivatives and that $f$ is arbitrary, derivatives must cancel on the left hand side.
$p_x[g(k)]=kg(k)$ is obviously solution. This in turn implies its definition in real space:
$$ p_x f(x)=-i\frac{\partial }{\partial x} f(x) $$
Indeed:
$$ -i\frac{\partial }{\partial x} f(x) = \int k \tilde f(k) e^{ikx} dk $$
- 137
