From observer point of view an object, which falls into black hole never crosses its horizon. Then how does black hole appears and grows its mass?
Or does any black hole looks (and feels by all other information sources) for us like a void sphere with all mass around its horizon?
klm123
  • 390
The Schwarzschild coordinates (which seem to suggest that no object ever crosses the event horizon when viewed from far outside) were derived for stationary case: no matter flows onto the black hole, the black hole has constant mass. In fact, Schwarzschild was assuming zero stress-energy tensor (vacuum solution).
However if you start adding a lot of mass to the black hole, the situation changes. Imagine you throw a little object towards the event horizon. It "seems" to freeze on the surface of the horizon (it actually visually disappears due to the red shift). Later on, there is a huge amount of material streaming to the black hole. It is thousands of times more mass than the original mass of the black hole. At this point the conditions under which Schwarzschild found his solution no longer stand, because the stress-energy tensor is far from being zero. The event horizon will grow, since it forms wherever the gravitational potential reaches certain value. By adding more mass you unavoidably enlarge the volume where the potential has the required value to form the event horizon.
The case of non-constant mass is described by the Vaidya metric. Mathematically this is described on pages 133-134 of this book.
mpv
  • 5,296
Mass still falls into a black hole, it's just that from the point of view of the mass, its last instant outside of the hole is infinitely long. The mass falls into the hole, but just can't perceive that it has.
We detect black holes because they emit x-rays, have accretion discs, and have a very strong gravitational field. We cannot "see" the singularity because it is hidden beyond the event horizon - we only detect its presence indirectly.
Dave Coffman
  • 1,561
That's more of an optical illusion than anything else. There is nothing that can physically prevent entering mass from continuing onto the center of the blackhole, so that's what it must do.
Theoretically, one could tell the difference between a true singularity with a concentrated central mass from a thin sphere with all its mass at the event horizon, but I don't we'll prove that anytime soon.
TTFN
IRStuff
  • 49
