I want to discretize the wave equation
$$\frac{1}{c^2}\frac{\partial^2\psi\left(\vec{r},t\right)}{\partial t^2}=\triangle\psi\left(\vec{r},t\right)$$
in polar coordinates. I find the following relations:
$$\vec{r}=r\mathbf{e}_r$$ $$\triangle=\frac{1}{r}\partial_r r \partial_r+\frac{1}{r^2}\partial_\varphi^2$$
Define:
$$r=i\Delta r,\qquad\varphi=j\Delta\varphi,\qquad t=n\Delta t$$
Thus:
$$\psi\left(r,\varphi,t\right)=\psi\left(i\Delta r,j\Delta \varphi,n\Delta t\right)\equiv\psi_{i,j}^{\left(n\right)}$$
Using the forward difference in $r$ and central differences in $\varphi$ and $t$, I get:
$$\psi_{i,j}^{\left(n+1\right)}=2\psi_{i,j}^{\left(n\right)}-\psi_{i,j}^{\left(n-1\right)}+\frac{c^2 \Delta t^2}{\Delta r^2}\left[\psi_{i+2,j}^{\left(n\right)}+\frac{1}{i}\psi_{i+2,j}^{\left(n\right)}-2\psi_{i+1,j}^{\left(n\right)}-\frac{1}{i}\psi_{i+1,j}^{\left(n\right)}+\psi_{i,j}^{\left(n\right)}\right]+\frac{c^2\Delta t^2}{i^2\Delta r^2\Delta \varphi^2}\left[\psi_{i,j+1}^{\left(n\right)}+\psi_{i,j-1}^{\left(n\right)}-2\psi_{i,j}^{\left(n\right)}\right]$$
Now this is divergent at $r=0$, did I something wrong?
And how can I set restrictions to the steps $\Delta r$, $\Delta \varphi$ and $\Delta t$?
