In all the sources I’ve been able to find, the Minkowski metric appears ad hoc, or is defined analogously to the euclidean metric. I’d love to see an argument why this metric (time coordinates positive, space coordinates negative) must follow from the constancy of the speed of light. It is clear that the Minkowski metric is preserved under the hyperbolic transformation of space-time, but likely others are as well. Why this particular metric and not something else.
Consider the determinant function of an n by n matrix. It has a god awful mathematical form involving the sum of n ! terms. Yet all you need to get the (unique) formula are a few postulates — the determinant of the identity matrix is 1, the determinant is a linear function of its rows (or its columns), interchanging any two rows of the determinant reverses the sign of the determinant, etc. etc. This basically determines the (unique) formula of the determinant. I’d really like to see the Minkowski metric come out of something like that.
" I’d love to see an argument why this metric (time coordinates positive, space coordinates negative) must follow from the constancy of the speed of light. ... Why this particular metric and not something else.".
Well, there is nothing mysterious, or even unusual about the signs of the metric. If you take a look Einstein's "Relativity: The Special and General Theory", you will find in the Appendix I (just before equation (10)) that in order to derive the equation, Einstein simply started off with the Pythagorean Theorem in 3D, which he put like this:
$$r = \sqrt{x^2 + y^2 + z^2} = ct$$
So what he proposed (as well as Minkowski himself) is to show the vector of light traveling in a three dimensional space.
He then squared both sides and moved $c^2t^2$ to the left changing the sign. This gave him the signature [$-, +, +, +$] Obviously, you are equally free to move the $x^2 + y^2 + z^2$ to the right, in which case you will get the signature reversed [$+, -, -, -$]. Apparently, that's what Minkowski did.
The same equation was then build for the primed (O') frame of reference, and both frames were compared.
Now, if you want to compare two different frames of reference, two different spaces, without actually measuring different values, you need to find something they have in common. This common "thing" as assumed by both Minkowski and Einstein was the speed of light, which allowed them to use the equations $c=x/t$ and $c=x'/t'$.
But then, the constancy of light is not necessarily the cause for the particular signs for the metric Minkowski used. As you can see above, the signs would change the same way if you assume that $c'\neq c$. What you do need, however, to develop the metric the way Minkowski and Einstein did, is a way to present the vector in space. They did it through the concept of speed of light (which obviously entails the concept of time).
bright magus
  • 1,585
